I have two screw types that I need help with to know which is best to use with 16mm MDF for my woodie cabinet, the MDF has veneer on both sides and is 16mm thick total, the two screws I have are: the left one is a 32mm pine wood screw with less ridges and the right one is 30mm with a bigger head and more ridges that I got from a kitchen manufacturer he said that is what they use for their MDF, the screws are going through 19mm hardwood with the holes honed and countersunk and I'm aiming to drive the screws 12 to 13mm into the MDF, the hardwood will be support rails for under the controll panel and to support the weight of the CRT monitor. I could grind down the tips by 2mm or more if this would help have more thread grip but I need advice on this too, I won't be glueing the wood with the screws. Should the MDF be pre-drilled or drive the screws straight in.
Potostew42
6 answers to this question
