Gemini2544 Posted December 14, 2021 Share Posted December 14, 2021 (edited) Well here we go! For those that have never seen a Take Five Cocktail pinball machine this is one. I had some interesting times looking after one at the "Daily Planet Brothel" that's another story on AA some where! Anyway fond memories! What I have here is a machine with no real chance of living again other than- A/ Finding a working MPU board (Unlikely). B/ Locate the missing dedicated CPU (found), RROIT (prototype replacement found), PIA IC's (found). B/ A replacement RRoit board in Canada and here in Australia (still a project). C/ Put another board system inside (Possible). So this is a TAKE FIVE, it's a Table top Solid State (SS) pinball machine with a much smaller footprint than a conventional Pinball machine. Now this game has no working MPU so the project will be slow. I hope you enjoy the journey. Edited May 26, 2022 by Gemini2544 Typo 5 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 14, 2021 Author Share Posted December 14, 2021 (edited) Okay the first job today was to remove all the ZOMBIE wiring someone did to make the game sort of play. No scoring, no ball count, no end of game, just the walking dead! If you have a keen eye you'll see the wires removed. Were now back to the factory original wiring. So much easier to read the schematics without a bunch of bogus coloured wire that doesn't belong. Edited December 14, 2021 by Gemini2544 Link to comment Share on other sites More sharing options...
thejudge Posted December 14, 2021 Share Posted December 14, 2021 So I assume this is the project that I have been providing parts for 😁 Looks like a fun project, I wouldn't mind giving one of these a go one day, that's if I could find one. Not sure if i know enough about Gottlieb sys 1 boards to get one working, I'd probably try the audrino method as that looked very interesting. 1 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 14, 2021 Author Share Posted December 14, 2021 Yes, Some of THE JUDGE will be inside the machine 100%. Thanks for that too! I can't stand seeing a machine die, their always fixable. I looked into Audrino but I can't write "+C" so that was that! Link to comment Share on other sites More sharing options...
thejudge Posted December 14, 2021 Share Posted December 14, 2021 9 minutes ago, Gemini2544 said: Yes, Some of THE JUDGE will be inside the machine 100%. Thanks for that too! I can't stand seeing a machine die, their always fixable. I looked into Audrino but I can't write "+C" so that was that! I was a programmer in my pre-retirement life that's why I'd go that way 1 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 14, 2021 Author Share Posted December 14, 2021 1 minute ago, thejudge said: I was a programmer in my pre-retirement life that's why I'd go that way The best I can do is BASIC & even that's sketchy now. Just got word from RTBB, the missing plugs I need are out of stock.. That's going to slow me down greatly. Someone surely has a dead Gottlieb harness floating around, I really need these plugs. A1J6, A1J3, A1J2, A3J2 That's all! Link to comment Share on other sites More sharing options...
thejudge Posted December 14, 2021 Share Posted December 14, 2021 If no luck with the connectors, I got mine from here https://www.docentelectronics.com/httpdocs/AmusementGames/Pinball/Gottlieb/System One.htm 1 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 14, 2021 Author Share Posted December 14, 2021 (edited) I ordered four 3ag fuse holders to replace this poorly done replacement, at lest it was fused. Note the fuses soldered in as well. Better to replace all four and be done with it. Edited May 26, 2022 by Gemini2544 1 Link to comment Share on other sites More sharing options...
thegrunta666 Posted December 15, 2021 Share Posted December 15, 2021 Those fuse holders look just fine to me....The solder is to make them vibration proof. These mods where done by a true professional back in the day 😁 1 2 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 15, 2021 Author Share Posted December 15, 2021 (edited) On 15/12/2021 at 3:41 PM, thegrunta666 said: Those fuse holders look just fine to me....The solder is to make them vibration proof. These mods where done by a true professional back in the day 😁 More likely a true act of desperation, also the 35amp fuse inside the holder was a "Just to be sure" fuse. Edited May 26, 2022 by Gemini2544 1 Link to comment Share on other sites More sharing options...
Autosteve Posted December 15, 2021 Share Posted December 15, 2021 4 hours ago, Gemini2544 said: More likely a true act of desperation, also the 35amp fuse inside the holder was a "Just to b sure" fuse. That would make it a highly reliable fuse. That is a fuse that is never going to blow if you look at it that way. I actually had a customer say to me once can I get some reliable fuses off you because the ones I'm using keep on burning out. 1 Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 16, 2021 Author Share Posted December 16, 2021 (edited) Some work was done today but not electronic. As I'm behind the 8 ball with the plugs I decided to start some work on the cabinet. Had some chipboard damage to bog up. BOG must be one of the most useful thing on the planet. Edited May 26, 2022 by Gemini2544 1 Link to comment Share on other sites More sharing options...
kimbleseven Posted December 16, 2021 Share Posted December 16, 2021 Good work Doug. You are like rocky you never give up! Another machine hopefully saved! Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 16, 2021 Author Share Posted December 16, 2021 13 hours ago, kimbleseven said: Good work Doug. You are like rocky you never give up! Another machine hopefully saved! long way to go yet, Jesse. Link to comment Share on other sites More sharing options...
Gemini2544 Posted December 30, 2021 Author Share Posted December 30, 2021 (edited) A 100% fluke & just luck. I was talking to a guy in the US about something else when he gave me a lead for a "H" MPU board. I contacted this guy called Rick who has a Roy Clark table, same game as the Take Five. He has a stuffed power supply so he is going to part it out. I was able to buy the board for $200 us. Edited May 26, 2022 by Gemini2544 4 Link to comment Share on other sites More sharing options...
Gemini2544 Posted January 23, 2022 Author Share Posted January 23, 2022 It's here! One very hard to get "Take Five" MPU board. Arrived from America this morning. So happy it's here in one piece. The board has never been molested, completely clean of repairs & hacks. 5 Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 24, 2022 Author Share Posted May 24, 2022 UPDATE: This board will be soon back in hand to test a repair mod, More about this when the repair and mod testing is complete. 2 Link to comment Share on other sites More sharing options...
ajfclark Posted May 25, 2022 Share Posted May 25, 2022 If you want a second one, I found one here in Horsham that the guy might be willing to part with. He's also got a Sure Shot that needs a little love. Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 25, 2022 Author Share Posted May 25, 2022 1 hour ago, ajfclark said: If you want a second one, I found one here in Horsham that the guy might be willing to part with. He's also got a Sure Shot that needs a little love. You should grab them Andrew. Link to comment Share on other sites More sharing options...
Autosteve Posted May 25, 2022 Share Posted May 25, 2022 His got a point, Sure Shot is a great game. How's that Take Five going anyway?. How about some pictures of it's internals?. I think people would love to see how Allied Leisure did things in those tables. Always believed the concept was there but the brand and playfield layouts weren't. Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 25, 2022 Author Share Posted May 25, 2022 11 hours ago, Autosteve said: How's that Take Five going anyway?. How about some pictures of it's internals?. I think people would love to see how Allied Leisure did things in those tables. I have these pix on file. 1 1 Link to comment Share on other sites More sharing options...
Azure Posted May 26, 2022 Share Posted May 26, 2022 (edited) I have the ALI main pcb from @Gemini2544. He kindly lent it to me to test a 6504 NOP module I had made up. While I was waiting for the NOP pcbs to arrive for testing I did a little work on his main pcb (which is not working). It turns out at least one of the 6530's are faulty. So after a little research I started designing a small plug in replacement that can be configured with solder jumpers to be the one you need to replace. After looking into available parts I went through a few design revisions. PCBs and parts for testing were ordered and am awaiting pcbs to be delivered. I hope to have some of those pcbs here next week to start assembling them and developing the configuration files to test them. The 6504 NOP works, which is nice for fault finding a faulty board. With a working board signatures could be recorded to make fault finding easier. @Gemini2544 has kindly agreed to let me hang onto the ALI pcb a little longer while I develop these 6530 repro modules. In the next batch of test pcb's that are coming I have also made a Fluke 6502 to 6504 adapter. If that works I can also test the board with a Fluke 9010A to do RAM, ROM and Port tests. While I was working through different design options for the 6530 repro, to come up with something that seemed workable and met my criteria, I started on another (slower) project... a repro ALI main pcb. There were requests to produce a smaller pcb and remove the messy jumpers. . I initially drew up the schematic and pcb layout using a rev E schematic. I then did a revision change to match the current rev H pcb, this is the pic below (J4-J6 are wrong). I am using this as the stating point for my repro ALI main pcb. It will be smaller and will use a different method for the settings. A little work on the code shows the settings are read in real time, so I am (almost finished) reverse engineering the code to see if I can change the way the settings work without changing the game play. This project (ALI main pcb repro) will pause as my other little projects get worked on. I also started thinking how I test things - I do not own one of these games! @Gemini2544 has kindly volunteered to test the bibs and bobs for me when they are ready to test. I still feel a need to make testing easier. So I started designing these..... Early stages so far. Top has a socket soldered onto the pins to plug into the main board and bottom plugs into the harness socket. It can be used to check or test lamps and switches plugged inline (into board and harness), board only or harness only. Top has 2 rows of LED's to show if that pin has a switch pressed or lamp on. Switches have pin number and abbreviation of normal function above them. Unused pins can have switches and LED's left off or if all on 1 board can be used to test any of J1-J3 lamps or switches. I have added all as stuck lines on a rev E pcb can will show up that can cause problems you might not notice on a machine wired for just rev H. I made up a tester (breadboard with ATMEGA 2560, sorry not sharing a pic of that) to read the 6530 RRIOT and verify if the rom and ram are ok. That could be developed into a proper tester to verify the ports and timer as well. I will leave that for later if I feel the urge to develop it into something more useful. Hopefully that gives a few pics and some info about the bits I am working on and their progress. Fingers crossed @Gemini2544 will have his board back in his machine and all working again soon. Edited May 26, 2022 by Azure 2 Link to comment Share on other sites More sharing options...
Autosteve Posted May 26, 2022 Share Posted May 26, 2022 Nice work you guys have organised. Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 26, 2022 Author Share Posted May 26, 2022 7 hours ago, Autosteve said: Nice work you guys have organized. John is the brains on this, I'm more a contributing spectator. 1 Link to comment Share on other sites More sharing options...
ajfclark Posted May 27, 2022 Share Posted May 27, 2022 On 25/05/2022 at 8:38 PM, Autosteve said: His got a point, Sure Shot is a great game. It is. I'm just out of space at the moment, and it needs a little love... Left flipper is starting to drag, there's a bit of wear here and there, the backglass is pretty good, the leg bolt plates need replacing at the back (it's sitting on a box at the moment), the back to the light box is a piece of cardboard. He's asking $2k. On 25/05/2022 at 8:38 PM, Autosteve said: How's that Take Five going anyway?. How about some pictures of it's internals?. I think people would love to see how Allied Leisure did things in those tables. Always believed the concept was there but the brand and playfield layouts weren't. I often wonder if part of the issue was that multiplayer games involved people standing up and moving around. The cocktail arcades at least sometimes flipped the screen etc which made things more bearable. Link to comment Share on other sites More sharing options...
