Capcom system 11
Have a system 11  capcom with an xmen vrs street fighter. All plays fine however can't get sound. Roms check out ok in test including sound rom. It does mention codes in menu could this be the issue currently I have no idea what the code might be?
Also, who is the person for Pcb repairs in Australia. I would like to perhaps change the battery in this before it becomes an issue and have other pcb games that need repair.
Thanks.
3 hours ago, Arcade King said:
@Womble and @Jomac do PCB repairs.
Code is probably the number for the sound or address for sound test.
Do you have another CPS2 board you can swap the top and bottom around to verify if its the PCB at fault?
No other games I'll keep an eye out for one.
41 minutes ago, djsheep said:
There’s a super capacitor that goes bad and takes the sound with it. I have a couple of spares and can help you out.
Worth a shot, thanks. I’ll pm for payment postage details.
Not a super cap... When that goes out your sound settings are forgotten and don't match what's in the EEPROM...  They usually end up at full blast.
Hold down the volume down button while you turn on the game and hold it until you see the splash screen. That will reset tha audio. It happens sometimes when you swap carts around.
BTW: This is Capcom CPS2, not System 11.
  • Thanks 1
