Gunna Fathom am i going to finish this
31 minutes ago, Pinoffski said:
I will look into a bit of stainless if it don't cost a bomb
prices are crazy stupid for anything
Looking into the colours
My pick is the for the citrus 3rd from left, light blue maybe 2nd from left, dark blue 3rd from the top
not sure if you're keen on keeping the serial numbers/letters, or just going to fill them, but using a very narrow jewelers screwdriver you can gently tap, going over the original letters/numbers to retain them.
not so hard that you lift the ply, and it is tricky doing the curves, but achievable.
  • Thanks 1
I like Rich's Aluminium sheet idea to replace the horrible Bally metalic painted cardboard in the backbox. So much easier to work with than stainless sheet. You want it to shine like stainless, polish it.
.5mm thick would also means no sharp edges unlike the original Bally metal sheilding prior to the ridiculous cost cutting idea of metalic painted cardboard that just loves to bow and short against the back of your boards in extreme cases.
2 hours ago, Pinoffski said:
Going to put aluminium sheet in as per @Rich
Will need 535mm x 1020 or bit longer
Got this pic off pinside
Resized_eacdd677c849f372fcdce5b72aeec9201b27b1a2.thumb.jpeg.ac69f761f4ea2f2b17e33d0037bbe501.jpeg
If you want it looking real pretty, being aluminium means you could get the sheet anodized. Would look sharp but just how much of it you'll be able to see when all the boards are in, the tech sheets are put in place and how often the backbox is open for all to see is what I question.
Still, blue anodized aluminium does look outstanding..😉
Not much of a update..
I was hoping I could of got the paint that others have used as I wanted to have it as close to original..
Was going to rattle can it .
I puchased these paints and it cost a bomb.
Price was triple from the last time that I purchased..
If you know the exact paint formular there is a place in Milperra NSW that rattle cans it for you. Last ones I had done come in at about $25 a can and about $20 for clear. (2 years ago)
Probably not open ATM on account it is in Australia's most infected areas right now.
How will you apply it @Pinoffski ?
5 hours ago, Pinoffski said:
The back glass was the best part of this pin .
I had it stored in the bedroom. Lol
It has started to lift.
Not happy but will look for a replacement
They just don’t quite get the colouring right. My Paragon replacement was way better than the one I had in it condition wise but colour wise it was chalk and cheese.
  • Thanks 1
