Bally leg brackets
Just wondering if anyone has upgraded their leg brackets and has their old original  Bally leg brackets  hanging around. I’ve just started putting a supersonic back together and have discovered one is missing and one is only half of one!  Take a look a the picture. I’ve never even seen just 1/2 before!
so I’m hunting for 2 legs brackets.
I don’t mind if they are rusted to all hell. I’m happy to restore them.
On 18/08/2021 at 9:00 AM, ajfclark said:
If they're the same as (or compatible with) the williams ones, I have a few about, but It's probably cheaper to just order some from RTBB?
https://www.rtbb.com.au/product/leg-bracket-01-9296
I think they are the same. None in stock locally. They are pretty cheap from PBR (under $3 each) but of course the postage is insane. Annoyingly I’d only just ordered some flipper rebuild kits from them before I realized I needed the leg brackets or as I now know them to be called “leg tees”.
If you do have a couple lying around how much would you want for them?
2 hours ago, wiredoug said:
they're 2.75 new ?
RTBB was quoting 5.25 and I just rounded up. As PSPA has them listed cheaper, sure, I'd do too so I can restock.
But it's moot if PSPA is back in stock, just grab them there.
Edited by ajfclark
13 minutes ago, ocyen said:
Don't bother with these old style leg brackets. Install some of the newer WMS style brackets which mount to the adjacent sides of the cabinet. Much stronger.
Agreed. I used these in my pinball pool, much stronger
Edited by thejudge
