How to switch 15Khz to 25Khz on Pentranic Monitor?
chaos199
I have a Pentranic 1431 (used for 32inch crt), that I have always had on standard 15Khz. I would like to find out how to switch it to 25Khz and am aware of the plug to obviously switch it over to but would like to know it there is any other plug/setting adjustment I would need to do before turning the monitor back on. I also would like to know what difference (if even slightly) should I expect in the picture quality if I am still using the same old game system that supports 15Khz. I used to have a street fighter vs capcom but now I just bought a pandora's box for mostly old 2D games made for CGA output.
3 answers to this question
You don't want to do this. The only reason to switch to 25khz is if you have a specific game that outputs a 25khz signal.
If you're running a Pandora's Box, you want to keep it at 15khz, as that is the output that the Pandora's Box supports. AFAIK, Pandora's Box only output 15khz or 31khz, not 25khz.
