SS "bongs" at start up
ricindahunting
Good morning guys and girls
As stated in the title when I power up my Scared Stiff it continues to bong and show the start up phase in the dmd. it resets and does it again yjen just bongs showing nothing on the dmd. Any help would be appreciated. I went to pinwiki but as an amateur its like being stuck in a maze!!!
Rich...........
5 answers to this question
How many bongs? just 1? if so it could be a low 5 volts triggering the voltage monitoring IC and resetting the machine which is a common fault.
Check the plug at J129 on the driver board for signs of burning. Also try reseating J101 (on the driver) and J210 on the CPU. If this fails you'll probably need to get the board serviced.
I did one of these recently for the Pinball Haus with the same issue.
  • Like 3
