LAI TMNT cabinet minor restore
Pac daddy
Hey guys i thought since i couldnt find anything here detailed about a LAI tmnt cabinet i would post pictures and process of a minor restore and clean that way anyone else whos intrested in a similar cabinet can get an idea of the insides and out if there not familar with one like myself :)
p.s
be easy on me first time doing this so im going to need some advice
17 answers to this question
May seem like a noob question but im not familar with this connection type if you guys can help me out
A couple of to do things im looking at getting done
my rear exhaust fan dosnt seem to be working and would like to replace with a new one
my aracde psu has a fan and also isnt working
also my marquee light globe is blown but im wanting to put a led strip to allow less heat stress on the marquee how do you guys add extra power connectors
the right speaker is blown and crackles can these be changed with similar spec one
Tbh I wouldn’t bother with going LED, it isn’t worth it. The original fluro tubes don’t run hot and if heat wasn’t a problem in the days where the cabinet ran 16 hours a day non stop it isn’t going to be a problem for a cabinet getting home use. But probably the biggest issue is that LEDs are very directional, even the tubes, whereas a fluro gives light out over its entire surface. An LED strip would give a very bright stripe behind the marquee and look weird, so you would have to find a very wide beam tube or work out a diffuser system.
Basically you are solving a problem that doesn’t exist, and $20 at bunnings will get you a new tube and starter.
  • Like 2
Thank you womble i will take your advice
i just had this theory in my head that the fluro light would put unwanted heat on my marquee display image and cause damage as the rear perspex seemed discoloured
Also is the power plug with a pointed tip a standard plug say from jaycar im into computer building but its a connection im not familar with
thanks
Hey @Pac daddy
Heres the one I restored
https://www.aussiearcade.com/forum/s...-updated/page2
If your credit system isnt working as intended, I also put this up (see last post)
https://www.aussiearcade.com/forum/a...ai-tmnt-wiring
I cant really speak for the arcade PSU fan, as mine doesnt have one - but the rear cabinet fan on mine is connected to mains / distribution. Maybe just measure the diameter and search a generic replacement. Jaycar seem to have a whole range on their website, and the usual electronics places
Noticed you have a 2 player Street Fighter panel at the moment. If you cant find a replacement - Brendan Richards on facebook (not sure if hes on the forum, but try this link or search his name https://www.facebook.com/profile.php?id=100004639428592 ) makes new steel panels for these, and then of course Carson @MamePatrol from noodleshirt.com can do all the artwork for these, from marquee, to credit area, to panel overlay
The factory redford speakers are 8" and 8ohm. Most guys use these as a direct replacement: https://www.altronics.com.au/p/c2000...ne-pa-speaker/
A lot of these cabs get converted to other games over the years, and the 4 player wiring and credit system gets messed about.
If you get stuck, feel free to reach out. Ive done somewhat of a harness restoration for another member on here previously as well as my own
Thank you mr jamma very detailed information much apreciated
as for your post on your restore very nice machines the astro city looks beautiful let me know if your looking to get rid of it:rolleyes
Just a question about the 8ohm speakers are they the only ones im able to replace with or am i able to use 4ohm speakers
Currently both speakers wired in parallel and 2 wires run to the jamma harrness
From my understanding that would output 4 ohms from jamma board correct me if im wrong with this theory
hey @Pac daddy
TMNT PCB manual is here: https://www.arcade-museum.com/manual...89__Konami.pdf
From the manual, it would seem its indicating it is 4ohm stable, which would mean it can either take a total impedence of either 4ohm or 8ohm safely
Based on the pic it seems to either want:
1. 2x 8ohm speakers in parallel (which should provide a 4ohm impedence from the 1 pair of wires coming out)
or
2. 1x single 4ohm speaker
or
3. 1x single 8ohm speaker
Has a big cross through the use of 2x 4ohm in parallel.
Also no mention of wiring in series in the manual.
I would play it safe, and grab a replacement (or even a matching pair if you prefer) from the link in the previous post, and run 2x 8ohm parallel
Edited by mrjamma
Let me know if you want any info on the harness wiring, I have put together a block diagram and connector wiring for the LAI TMNT cabinet.
Can't help with the pcb adapter cables as that is what i am missing on the cabinet I am working on (info in another post).
