So a while back I landed myself a Sord M5. They're a cute little computer that uses the same TI99xx graphics chip found in the vast majority of 80s consoles & computers (Coleco, Sega SG1000/SC3000, TI99/4A, Memorex MTC, MSX etc etc). While launched in Japan, they did see a wider global release but ultimately suffered the same fate as so many other early 80s computers - existing when the Commodore 64/MSX/ZX Spectrum were booming.
(and no, it's not yellowed. that's just how they came!)
While this one came with a bunch of games, it was missing three things: Joysticks, the cover that goes over the top half of the Sord, and a PSU. While the cover is probably nigh on impossible to find, the PSU (and later on, the joystick situation) is something I can definitely deal with sooner.
Problem is there's not a lot of info out there like the other popular systems of the era, however thankfully a local friend has a complete M5 including the PSU that I could check to see what voltages it put out. The Sord uses a 6 pin DIN plug, with pins 1/2 being Ground, pins 3/6 +5v, pin 5 -12v, and pin 4 +12v. Something all PC power supplies will happily provide, but I settled on a spare AT PSU I had here.
The second image is a partial (?) schematic for the Power Brick that shipped with ​​the Sord M5 that I managed to find on archive.org. The pinout there is for the DIN plug coming from the PSU, not the connector at the computer end, something I nearly learnt the hard way!
After getting the wiring right and connected, was time to test it out:
Success! All that's left to do for the PSU is to get out the hot air gun to shrink the wrap on each pin, then assemble the DIN plug. Will also tidy up the excess PC leads & do something with the power switch - although given these are super common voltages, I may look around for an alternative supply that isn't so huge!
Next steps: Sort out the controller situation & figure out why the sound doesn't work.
Edited by darkjedi NUked the incorrect controller info link!
darkjedi
Edited by darkjediNUked the incorrect controller info link!
9 answers to this question
