Please use the contact form if you are having issues making an account or logging into the forum. If you need to contact somebody specific, do not use the contact us form. You will need to make an account and contact the person via PM directly. ×
Posted (edited)
SG-1000 RGB mod using an ArcadeTV SMS2 RGB Bypass Board. I built two of RGB boards a while back but a mate only wanted composite for his Master System so I had a spare.
The picture after install is sharp and clear, the following picture doesn't do it justice.
Taking the SG-1000 apart was a simple task and the console board has all the main video points labelled... easy.
- R, G, B, CSYNC are all labelled
- Audio and 5V are on the RF connector. Audio on pin 4 and 5V on pin 2
Install
- Open case
- Remove voltage regulator heatsink
- Desolder and remove RF module
- Remove and replace voltage regulator with something modern (optional, but removes the need for the heatsink)
- Remove link wire on edge of RF location and resolder jumper wire on rear side (see pictures)
- Solder RGB bypass board to main board using old RF case side mount points, matching rgb pcb GND points and some link wire.
- Solder all main board connecting wires
- Solder socket connection wires (I used an 8 pin min din socket with a nut threaded on to it to stay in place. Worked a treat and looks factory from the outside)
- Reassemble case and test.
ArcadeTV SMS2 RGB Bypass Board via Oshpark.
https://oshpark.com/shared_projects/Ntagdloi
File link to use JLCPCB or the like
https://644db4de3505c40a0444-327723b...8c2c31cbc3.zip
SG-1000 main board RGB wiring points
9oJxpgpqi_l1-aBxFZ1nU2g83vOJ-CnHMLmY7gJCUP91GxoWH4tgdgk9ehXzZsqfl9NXzPbT2vWkGE2m1c3zymZ0jV9JGq-YixruuQmhvSO8DQ1V7zeUMm4yjrUrExTCEuWe4yNGJ-blp2wZ-an97fuvOylZhPk3nXJg5dqOto3vbbseVNrC6Z5jiCO6PWZ5GUNc-gduk0GoE6plDW5p27z6jDmDGr8U6tvNXjrjzOeSSjZrhin3YyUbD4m1lkyw4AOApHcGiND1hJsrkAPTpajSkJlZy72mYK2hDE-g0UKskcrPeD3JyrsSdyHj5BZFysY9IlNMgV_m9KKi2SWMoZZajwEKfEBvlS4nMN6zyeoOE-OZE1PKKW19m_-OrZ2WGo9DMvRxRvb5XA4SgOVoQkk9XHWhIKRCpBNJxd-xktH3iGjJWeLcqH1FcuxzKpX-0lt1BR4ElA1FjNGFovWAdKSH9W8zhtN6Fr84uk7gwuqb6abD7E5hRdPn0eJN-UEkAqAQ9qc2RcBEhOCMNjy0TpPsOVIddR6sSxcEGMMPP3sgQOXlL9-Z4LjwATzesAkt-k8t2ZddaFFthAoyFRbxACqICcvUX2KqX1rquyQrHBr8rRQ289r9RQIvivoy8qfHrO4ORzDZExdKFaI19UTxu2Nwhl50mqF7faKIcDTon4nL2smMxeKJU27dZKmrWZm0AMu7Rl7quVJ4kN6-qCMN0ZbDjNSKV413F0I6djSET2nKj65nI1Edqg=w1000
RGB Board installed
v-K57qFP97MRtXysNkc6Yd-HI7hrDgSmfBfGu41kDbjb7nPpijZbDtVXyUheWUXsKGjLsMwbg-q1ZPyA9XAd46S1v65dyjp9kMY3J5qta055xXHgn0s04111AQhwUM6052DWgsEYsNAPVy5-JbBDsqUX9tlxUz_wLRbyPNnwGW5Y5j9ip_KKwsWm0tU8LWS_EQDiggz2f58RRRoXlooxF064A5vjtJgF-Sl9GqmN_GJrRF8GjKb0yZOSr5hbch3sC5rqwgQ3Xbs2OnHS9G6ScKRLFrtcSc3CBKuClS9hnVA_VKKpmGDCre06VpoFxpI3vqeJg1y_VhLSbzIy9FL_2lpad97o6yVURhuYCPiQr4PzQvKZc8mi224keKKBFdcGbv925vq4Gkugj632kopu7hNnI2Y3p-CczfMgQgXtjFJhGfw7L4Fgil3_2El1RbsVvoUPzefXNmwoEpDx9iu15AqL2Uk0JT71NyUVASUgB3pA4JCbLrR4Gk1sEM-Jh8DMiZmr5soC0MNh9y273GvxdYH4jkMy5BQwM8jb3cMySnn3wQELv3zCOZSLZoQHUii7HUKjoz3arjHm4V3ZNaPaTVyvZjsUigW6hPIYIl2gXGNkVALpTufdYVgryH5IEgfp-aIBfNETusqvitq1hlnps3YtL1tXO3d5LyZqshnvt4dILXR3e2zd0MWAVJ3qBeaooKwt6XVg1veEhYcEkQjKsUXSuvmmgVoEG5T1dd3LCJqhwGw19qcg1g=w1000
0vfXPcSaba0PUjxtqhBVY423sx7tDQ9ZoGwcRxLPSmuBC6mu00Pzyf4Oa4Gyyfo7gRG0G2D_TSlx00OququRmALSVSHvU7CiFkDoLVhwnGGYJkaxkAVedKmQrRiwLhevTPuqdyPTxFLKR3j_9_LpZanmBqzEDzChbmLVifmoX9ZNgEJM4wz7luaBRhBo0yLies2ubXnf0Dc_H1-IBb5TuBgOADJHJ5x0EEt0Hc3quxWZZJ2UFh7nabwEO0cuiKf6v4f8oakgqtzB5xDIfCXsT-WVeHDVGNH13Lp65MRV7qo_4rHpxhZl440Gq5H1bRFH6zomRf7YyebKksPz3Az441FdtCpkLU1xwDio-lXJADAHk70thir8Y09H1dK6TBNsW4ehBEokk-QUODmUWOQp--2_ZWBEH9ZIs52AvYr2WQlWntSlsq-UEow8j4Un8c1pjVVnp6OAZ6G4tlERj2YaW42nPNeIvziNYYOSGRFAvNB5Xl-j0Ep2SfvlOQhbN-AQH-7pi4zqyZ05pyX_umWYt4iI7WzkXkGiWQ6sANEYo2rIpduq7N3-NV557AvBekxWydrl0i7Q5cJ_DJdo8ZhPJdpW-bDes43khXwztwoc_wpFfIy49sIVgejrTTG3d9MJzxx9ZwuSCy-hQlvRyccRfn4LEiO4O-JkkpfYlp2MZfIKoRSqiJdMrgsbvrvIo2ogRwH7v-defmPUFaXbrRRW30fTBeDibXNyy6KWZdSddPaq8pHEilJCPA=w1000
Rear connector
wDrmcTLshaaDD6rJ238HjVOh1kdoceietbIXCSAVjJWO9QfC2m13rzmlOuSQTiL4jQUzra7IxGFuHIGN-6nnSPHnRZRerREatGA4NWuPnWt8805SSH04YCn7C9tRGaN23qvCAUSvpTSWHf5Cvz9cprtVJGwyvsHtqq0H_93lpeYcAzbW7SDGJYQJriCcuKW22_G-h-Xm0BHKlm5QFt_nsl34Yvy4l-FLoSob-aGOzO9ZMSiyIjwEXOtMgFuZHiSPAM1K3omEAA7mFDC3f_i_m3AlOwy_8dWzKiAObQvFZvv5t56QRMpz3IKwmk32Trrdtqs63lx7fWNQiiHBnQAnfQf2IWOKHBxVAdmkjTDUf2j1FkVGbk3_Gdjw7OIyTuzkfeqWI1RiOaaM7c0mU_36LE7XTqGGpdwRBlzZ8zcqy9-cNKFc7J_OZ009jLUbQIiwtimoTkZ7Og4nAircequLk_bx7IMPahfj6XdYyEVp6s_yrsIXvymrCqqLcV1NorOiPY1_427jl5gUK2JKqx7yYZNF2psiB2OQJ_P09_dnMXPnwF0Is4T7pF3rVES0NV0B5aaTtXxVuTP85Rt5cejUDGSK1lUpZ7CTXZHZWoh6w_Gf3cZeV8H7IKoLKgYcYdHs9mo9rgwNef9z-RhyyPyT-gJnQASE-Cuadi1JwCCfbNlHjNGjX8jLhILeE2qtTx4xL9UBHmYUfHpySVKZz8-34h7irpixicZLQE-vJy5GeWouBXfs14-EUw=w1000
Zaxxon in RGB (image isn't even close to how sharp and colourful the picture is)
m_O9oISzSSP1MsRuMDC7o1sdERCkcvqZqL4YUAmq5kAEz-2GHTcqBtRbBxmd36l9njIkoyontE7QUMWF6elqRrKukwO2EmtTcUtgotAV0dJcQ24kBASr3RZErPG-jbjTMB2i331ROCtMHN3DMcAg75sN0Y6olsg127pV6tHuLYg2usfpWw776bNigK_z9nv5DeVUxQWDAObz32G24kjZ-1d73H44v97qAKyPYpZqehipmLZ4P25wgmAUUZPEr0l31ETj7dNimwLUmtgQkK4aemNIcur6N59Eb4XQBi1j5ykAb1xs41te2m5V8I0cXiiFqF8Goqd56RAmtOdX2ZO9wWrNhtWiUJb1S5eJM4EsYbn2sIWDRB1ryRi5FnEXtX5N2eMiUz7v6SAc96GJoa2rBp2aBiUPK7KzrV8it1GNN2XiK7IyTshyZ1Mu72ORV1sDy2EdAv9jW2Wq8Ydjfp3puZCHdirjahERqjIWrg0oGGAVYMS7zvaEv1c8jOYz-raVAivx30zT3gyRk3jCejZTIyWzaF0e7kbad6Gc_9qujXJRMyjJ_MLRY-zPOUQt6IzPxFOhsSXQmqts15SPH6_eL854fLxe-k7bpYRog7MIEAA_1ebbaidIt9ERQpsQhKlOSBL4vjoA1GeimOckbXTTPAZfp6Ob1_ksv4vuIKQo6EAXr7kYo0VNet7VDhFznSTktB-Mz3qSr9koWt8X1P-4-Y4TMYJ3CTl91W7xWKiuCH-UHZ51eEZQPw=w1000
Edited by waali
Added a picture
Posted
Cheers. Played it a bit today. Kids never really believed us when we said that the games we played when young were for the most part more difficult than modern games... they believe us now!
