Due to a large amount of spamers, accounts will now have to be approved by the Admins so please be patient.
- 0
How to Unlock ALL Characters on Marvel vs Capcom 2 NAOMI
Recently Browsing 0 members
stu
This question gets thrown around alot.....and there are various bits of info posted around the net but i'll post it here for anyone who cares.
THIS INFO IF FOR US/EXPORT VERSION ONLY!!!!!! (the japanese version has different codes)
The game uses a 6 button layout, we will number them so you just have to press the button numbers for the codes. This is the exact layout/numbering of the buttons.
1 (light punch), 2 (heavy punch), 3 (assist 1)
4 (light kick), 5 (heavy kick), 6 (assist 2)
1 2 3
4 5 6
Different region bioses sometimes have different names for menu options, so the exact terms i will use are for the US bios.
Step.1
- Go to the systems test menu (press the test button on your cab or naomi board)
- Then goto "GAME TEST MODE"
- Goto "GAME CONFIGURATION"
Step.2
Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DEMO SOUND" - Press 635241 - Level 24 - 16 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 24 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DAMAGE LEVEL" - Press 563525 - Level 48 - 8 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 48 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"CONTINUE" - Press 121342 - Level 72 - 8 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 72 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DIFFICULTY" - Press 243161 - Level 84 - 4 More Characters & 8 Colours
That should unlock all the extra characters without having to play the game for 3333333333 hours.
NOTES:
- You have to do each code then exit the test menu, then go back in and enter the next code. You can't do them all at once. You have to do them in order....you can't just do the lvl 84 code first.
- Any button or joystick press in between the code you are entering will cancel it out. It doesn't matter if you stuff it up, you don't need to go out of the test mode or anything, just enter the button combination again.
- All codes above have been tested by me and work perfectly.
- If you unplug the cart from the MB you will lose all codes that have been input and have to do them again. If you also reset the system settings or game settings to default you will have to input the codes again.
6 answers to this question
