How to Unlock ALL Characters on Marvel vs Capcom 2 NAOMI
stu
This question gets thrown around alot.....and there are various bits of info posted around the net but i'll post it here for anyone who cares.
THIS INFO IF FOR US/EXPORT VERSION ONLY!!!!!! (the japanese version has different codes)
The game uses a 6 button layout, we will number them so you just have to press the button numbers for the codes. This is the exact layout/numbering of the buttons.
1 (light punch), 2 (heavy punch), 3 (assist 1)
4 (light kick), 5 (heavy kick), 6 (assist 2)
1 2 3
4 5 6
Different region bioses sometimes have different names for menu options, so the exact terms i will use are for the US bios.
Step.1
- Go to the systems test menu (press the test button on your cab or naomi board)
- Then goto "GAME TEST MODE"
- Goto "GAME CONFIGURATION"
Step.2
Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DEMO SOUND" - Press 635241 - Level 24 - 16 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 24 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DAMAGE LEVEL" - Press 563525 - Level 48 - 8 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 48 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"CONTINUE" - Press 121342 - Level 72 - 8 More Characters & 16 Colours
Exit test menu and make sure the game now shows as level 72 and start a game to see some of the extra characters are available. Then repeat Step.1 Now goto the following item in the "GAME CONFIGURATION MENU" and put in the following codes.
"DIFFICULTY" - Press 243161 - Level 84 - 4 More Characters & 8 Colours
That should unlock all the extra characters without having to play the game for 3333333333 hours.
NOTES:
- You have to do each code then exit the test menu, then go back in and enter the next code. You can't do them all at once. You have to do them in order....you can't just do the lvl 84 code first.
- Any button or joystick press in between the code you are entering will cancel it out. It doesn't matter if you stuff it up, you don't need to go out of the test mode or anything, just enter the button combination again.
- All codes above have been tested by me and work perfectly.
- If you unplug the cart from the MB you will lose all codes that have been input and have to do them again. If you also reset the system settings or game settings to default you will have to input the codes again.
6 answers to this question
I have a MVC 2 setup here.
For Marvel vs Capcom CPS2
NOTE: (none of this is verified by me, just webcopy)
Fight as Lillith in Morrigan's body:
Highlight Zangief at the character selection screen. Then, press Left(2), Down(2), Right(2), Up(2), Down(4), Left(2), Up(4), Right, Left, Down(4), Right(2), Up(4), Left(2), Down(4), Right, Down. She will appear below War Machine.
Fight as Roll:
Highlight Zangief at the character selection screen. Then, press Left(2), Down(2), Right(2), Down(2), Left(2), Up, Right, Up(2), Right(2). Roll will appear to the right of Mega Man.
Fight as Shadow Lady (Super Chun-Li):
Highlight Morrigan at the character selection screen. Then, press Up, Right(2), Down(4), Left(2), Up(4), Right(2), Left(2), Down(2), Right(2), Down(2), Left(2), Up(2), Right(2), Up(2), Left(2), Down(5). Shadow Lady will appear below Gambit.
Fight as Red Venom:
Highlight Chun-Li at the character selection screen. Then, press Right, Down(4), Left, Up(4), Right(2), Down(2), Left(2), Down(2), Right(2), Up(4), Left(2), Up. Red Venom will appear above Chun-Li.
Fight as Orange Hulk:
Highlight Chun-Li at the character selection screen. Then, press Right(2), Down(2), Left(2), Right(2), Down(2), Left(2), Up(4), Down(2), Right(2), Up(2), Down(4), Up(4), Left, Up. Orange Hulk will appear above Ryu.
Fight as Gold War Machine:
Highlight Zangief at the character selection screen. Then, press Left(2), Down(2), Right(2), Down(2), Left(2), Up(4), Right(2), Left(2), Down(4), Right(2), Up(2), Left(2), Down(2), Right(2), Up(4). Gold War Machine will appear above Zangief.
Change character order:
Press Strong Punch + Medium Punch + Weak Punch at the versus screen to switch the second and first characters.
Continue attacking:
Press Start immediately after winning the match to move almost everywhere and have the ability to continue hitting the defeated character, even with super moves.
Selecting special partners:
Note: The following codes must be entered while holding Start before the special partner selection screen appears.
Unknown soldier: Hold Weak Punch
Lou: Hold Medium Punch
Arthur: Hold Weak Punch + Medium Punch
Saki: Hold High Punch
Ton-Pooh: Hold Weak Punch + High Punch
Devilot: Hold Medium Punch
Anita: Hold Weak Punch + Medium Punch + High Punch
Pure and Fur: Weak Kick
Michelle Heart: Hold Weak Punch + Weak Kick
Mighty Thor: Hold Weak Kick + Medium Punch
Cyclops: Hold Weak Punch + Weak Kick + Medium Punch
Magneto: Hold Weak Kick + High Punch
Jubilee: Hold Weak Kick + Medium Punch + High Punch
Rogue: Hold Weak Punch + Weak Kick + Medium Punch + High Punch
Psylocke: Hold Medium Kick
Juggernaut: Hold Weak Punch + Medium Kick
Iceman: Hold Medium Punch + Medium Kick
Colossus: Hold Weak Punch + Medium Punch + Medium Kick
US Agent: Hold High Punch + Medium Kick
Shadow: Hold Weak Punch + Medium Kick + High Punch
Sentinel: Hold Medium Punch + Medium Kick + High Punch
Storm: Hold Weak Punch + Weak Kick + High Punch
Use opponent's helper:
Defeat your opponent's helper in a single player game. Then, hold Weak Kick + Medium Kick + High Kick at the screen that displays the name of the character that won until the next match. If done correctly, your helper in the last match will be from your previous opponent's team.
Name changes:
Enter --- as a name to have the game change it to "SIN". Enter AAA as a name to have the game change it to "CAP". Enter MMM as a name to have the game change it to "MOT".
Blow up Tyrant:
Note: You must have a level two super bar and Jill must be out for this trick. Use her Tyrant Super. Right before Tyrant leaves use her Rocket Launcher Super. If timed correctly you will blow up Tyrant in a very humorous fashion. Note: Blowing up Tyrant gives no extra bonuses, damage, or points.
Alternate costumes:
Press High Punch when selecting a fighter at the character selection screen.
Hint: Shadow helper:
If you look closely at the helper named Shadow, you may notice that it is actually Charlie from the Street Fighter series. When you call him, he will perform his "Shadow Justice" attack, then land for a moment. Look closely to see that it is him.
Hint: Ryu: Transformations:
When you reach one power bar press Back, Down, Forward + Medium Punch to transform into Ken. To transform into Akuma (Ryu in black), press Back, Down, Forward + High Punch (with one power bar). If you want to get back to Ryu after transforming to Akuma or Ken, press: Back, Down, Forward + Low Punch (with one power bar).
Hint: Hidden area:
On the level with one of the men drying off in the background, hit the wall on the right at least fifteen times and it will break and reveal a new room that you can fight in. This is done easier when you use any form of Spider-Man, Venom, or Carnage. Stand on the right side of the opponent then press the High/Fierce Punch rapidly with Venom or press the High/Roundhouse Kick with Spider-Man. [screenshot] [screenshot] [screenshot]
Hint: Fight as Onslaught (Japanese version):
Highlight Zangief at the character selection screen. Hold Start and rotate the joystick twenty times in a clockwise circle before the timer expires, then press Low Punch + Medium Punch + High Punch + Low Kick + Medium Kick + High Kick.
There is heaps of hidden stuff in this game....more below
http://www.gamefaqs.com/coinop/arcade/code/562630.html
Ebay.....they come up for sale pretty often. I definitely wouldn't say they are rare, just that they aren't so cheap when they do come up for sale. The cart only sells on average for between $200-$300 USD.
Wish i had a known this before i sold my marvel vs capcom ,love the secrets in arcade games ,actually there not that many around ,much more are found on the home consoles.
Love the secret "tweaks" on my dungeon magic and bloodstorm pcbs
http://www.gamefaqs.com/coinop/arcade/code/583719.html
http://www.gamefaqs.com/coinop/arcade/game/568165.html
*snip*
Blow up Tyrant:
Jill isn't in MvC. She's only in MvC2.
