Pessimeister Posted March 21, 2018 Share Posted March 21, 2018 Hi Arcaders This part of the forum doesn't appear to get much traffic, but I thought I'd post my issue here in case anyone has experienced the same thing and knows a fix for it. Basically I've got a problem with my USB Hori Real Arcade Pro.3 SA that I've been using with my PC MAME setup for the past 6 months. After a recent Windows Update, the stick hasn't been detecting properly and bizarrely windows often fails to recognise it. The error that I'm getting is "device descriptor request failed" when I check device manager. I've tried uninstalling, rebooting and then plugging back in which has worked once - but then suddenly last night it simply stopped detecting again, making me switch to keyboard. It's quite a strange problem. The usb cable for the stick is quite long; I hope the wiring itself isn't the problem. Hopefully I won't have to get a new stick, as this thing is a brick and has been excellent for many RetroUprising marathons. The USB slot works perfectly fine with other flash drives, so I've discounted the slot itself being the issue. If anyone has any advice or similar experiences, feel free to pipe in. Cheers Pessimeister Link to comment Share on other sites More sharing options...
buttersoft Posted March 21, 2018 Share Posted March 21, 2018 (edited) @Pessimeister there are some generic fixes to try here - https://www.drivereasy.com/knowledge/solved-unknown-usb-device-device-descriptor-request-failed-for-windows-10/ Give those a try first, please, if you haven't already. See if you can find a windows 7 machine somewhere to test it on. And does the RAP3 have any function that allows you to select configuration while plugging it in? As in, you hold a different button while connecting to make it a PS3 stick, or PS4, or X360, etc? When it does show up in windows, when you look at control panel>devices and printers, what is the stick called? If it works on PS3, you could get some generic PS3 pad drivers and install those - not something i've had to do, there might be hoops to jump through. I have seen similar issues with several brand-name fightsticks and boards on Windows 10. Do you have the same problem connecting to a PS4/PS3/X360 console? If not, open the stick and take a look at the usb connection to the stick's PCB and test connectivity of each wire with a multimeter. Does the board have a USB socket, or is it using individual wires? If it's using a JST-XH connector or similar, can you pull the connectors out of the plug and make sure they're ok? Are there four wires, or five? If there's five, try disconnecting the shield ground, or even reconnecting it while the stick is plugged in. I've seen sticks that would only work with the shield ground connected, and ones that would only work without, depending on the cable or which socket on the board was used, so try some different cables in different places on the PCB if you can. Edited March 21, 2018 by buttersoft Link to comment Share on other sites More sharing options...
Pessimeister Posted March 29, 2018 Author Share Posted March 29, 2018 G'day buttersoft, Thanks very much for your detailed reply and assistance here (particularly the technical advice) I appreciate it very much. I've now since tested the joystick on three Win 10 PCs and a Win 8 laptop. All of them have this fundamental device not recognised script error which makes me suspect that the USB cable is the issue. I don't own any consoles more modern than a PS2 to try it on unfortunately, but I've learned enough over the past week to think that it's the device itself which is the issue. Other flash disks work well in the USB port I've been using the stick in, making me now discount any PC-hardware or Windows issue. Curiously though, when I've uninstalled from device manager, rebooted and plugged back in, the stick can sometimes work for a short 10-20 minutes before suddenly veering off in one direction in-game and becoming unresponsive. Unplugging, rebooting and configuring MAME can sometimes make it work again, but not for long enough to be stable for long term use. To be honest, I don't have access to a multimeter, nor the general confidence or wherewithal to pull apart and test the connectivity. The question really is where to from here? I wonder if its possible to go to a local electronics specialist/repairman and see if they can replace the USB cable? Can't say I've ever tried to get anything like this repaired; the stick itself was a hand me down, but a relatively expensive and robust one. It should surely provide plenty of hours more usage once repaired. Link to comment Share on other sites More sharing options...
feeras Posted March 30, 2018 Share Posted March 30, 2018 Hi, Probably a long shot but the issues you're having seems similar to what I had before with my USB Hori Arcade Pro EX. I found a solution to mine via this page: https://steamcommunity.com/discussions/forum/11/810938082126729875/ Like I said, probably a long shot as I think you're pretty much thinking it's the USB cable. Cheers Link to comment Share on other sites More sharing options...
Pessimeister Posted May 30, 2018 Author Share Posted May 30, 2018 Just to give this thread some closure: I ended up taking my Hori stick to a local electrical repair shop (Dave Cassells) As I suspected, the issue was with marks in the USB cable which was corrupting/weakening the connection. Dave shortened the cable and ensured all points were working correctly at the base of the stick. Long story short, my refurbished Hori is working again and I can now go back to enjoying MAME and games on RetroUprising. :) Thanks for the posters who tried to give assistance! Cheers Link to comment Share on other sites More sharing options...
Pessimeister Posted August 19, 2019 Author Share Posted August 19, 2019 I do hate to resurrect my thread from last year, but unfortunately some issues have arisen again with my Hori stick. Several of the joystick directions started to fail to work correctly after a heavy rage-quit from some MGL action awhile back. :redface I took it into a local hobbyist / appliance repairs specialist and he did his best to clean it check over the connections, but alas he wasn't able to fix it. So I was curious if anyone knew of a location or business that I could get to take a look at it and possibly get it working again? Maybe a local one in Melbourne? I quite like the stick and would hesitate to purchase a new one. Cheers in advance Pessimeister Link to comment Share on other sites More sharing options...
buttersoft Posted October 18, 2019 Share Posted October 18, 2019 Sorry, i totally missed your necro. Hmmm, how about trying someone in the FGC? You could get onto various SF or Tekken Facebook groups and see if anyone wouldn't mind giving it a look. That's going to be the cheapest option. After that, someone who makes fight sticks in Aus might be able to install a new encoder, if that's what's required. Link to comment Share on other sites More sharing options...
Jed Posted October 18, 2019 Share Posted October 18, 2019 I do hate to resurrect my thread from last year, but unfortunately some issues have arisen again with my Hori stick. Several of the joystick directions started to fail to work correctly after a heavy rage-quit from some MGL action awhile back. :redface I took it into a local hobbyist / appliance repairs specialist and he did his best to clean it check over the connections, but alas he wasn't able to fix it. So I was curious if anyone knew of a location or business that I could get to take a look at it and possibly get it working again? Maybe a local one in Melbourne? I quite like the stick and would hesitate to purchase a new one. Cheers in advance Pessimeister Sometimes this kind of thing happens when the stick has had a lot of wear, and the blades that trigger the microswitch don't have enough spring back against the shaft, because of wear they are pushed in too far. I've solved this kind of thing heaps of times by removing the microswitch, and bending the blade back so it sits out more against the shaft and then will more easily get pushed by the shaft on the switch. If you get my drift. There's nothing really to 'clean' in a microswitched arcade joystick, but tuning the blades often will do the job - or failing that, just replace the microswitches, they are dirt cheap and extremely simple to do even for someone who's never done it before. Link to comment Share on other sites More sharing options...
buttersoft Posted November 4, 2019 Share Posted November 4, 2019 No new arcade stick aimed at the FGC will use lever micros, everything is pin plunger now. His Hori RAP looks something like pic related. Is that what you meant? Any business doing electronics repairs would probably be able to swap the encoder, including that place you already tried, but you might have to provide the encoder. Assuming that's actually the problem. The stick itself wouldn't be hard to test with a multi meter, but i suspect your appliance repair place would already have done that. Link to comment Share on other sites More sharing options...
Pessimeister Posted November 16, 2019 Author Share Posted November 16, 2019 Thanks very much guys for the responses, appreciate it! I finally bit the bullet and took my joystick to a proper specialist - big shout out to Michael who looked after me from Arcade Classics in Melbourne. https://arcadeclassics.com.au/ Bizarrely, the only thing wrong with it apparently was that a connecting cable had been inserted incorrectly (backwards?) causing the directional problems I was experiencing. This was probably unwittingly done by the previous chap I took it to locally. Everything is now back to working order. The stick is great quality and I certainly hope to get back to using it for the next MGL. :) The whole situation does make me want to try and get a little more 'handy' in future! Link to comment Share on other sites More sharing options...
annabeltbaxter Posted February 11 Share Posted February 11 Hey, what do you think about upgrading to Windows 11? Link to comment Share on other sites More sharing options...
Juninater Posted February 13 Share Posted February 13 (edited) Have you tried checking the device drivers to see if they need to be updated? That's one of the first things I would do in this situation. Also, have you checked out any forums specifically for the arcade stick to see if there have been any known compatibility issues with Windows 10? Sometimes the manufacturer will have information on their website or forums that can help you troubleshoot. And of course, you can always check out the Windows 10 subreddit or forums on windows 10 product key reddit for any helpful tips. There are many professionals that might help. Good luck! Edited February 13 by Juninater Link to comment Share on other sites More sharing options...
