NEO-GEO Man Posted March 16, 2018 Share Posted March 16, 2018 It handles the MVS audio via a switch. Input is taken care of. I think the only thing missing is the SELECT button which can be resolved by only inserting a single cart. As far as I know, all MVS variants should work fine. I have a good 4 slotter LAI cab im going to one day fully restore to original, so the only thing i need select for is pausing games on home console mode. I reckon i could add select button support in pretty easy if i needed it, but dont anticipate it being an issue. This will probably be used for my Lethal Enforcers board i reckon, ive got a few here, but only one that has working audio. If someone comes up with a replacement audio board or a schematic so i can make one, im laughin. It all hinges on getting them before the leakers kill that little board on the under-side! Link to comment Share on other sites More sharing options...
NEO-GEO Man Posted April 3, 2018 Share Posted April 3, 2018 It handles the MVS audio via a switch. Input is taken care of. I think the only thing missing is the SELECT button which can be resolved by only inserting a single cart. As far as I know, all MVS variants should work fine. Hey you do know that all multi slot MVS boards have the joystick sockets right on the mobo? The select button wont be a concern on those, and this board can still power the board and feed the RGB out ;) Link to comment Share on other sites More sharing options...
Frank_fjs Posted April 3, 2018 Author Share Posted April 3, 2018 I'm a bit lost when it comes to all the MVS variants! I have a 1 slot with joystick inputs, very handy. Link to comment Share on other sites More sharing options...
xodaraP Posted April 4, 2018 Share Posted April 4, 2018 FOR SALE - Sentinel Supergun These are the ones I know MV-1 - 1 slot with metal cart housing, first model and longest of all boards, has memory card, joystick ports and stereo out MV-1A - As above but plastic housing MV-1AH - Long board similar to 1A MV-1B - Smallest of all models MV-1C - Vertical loading 1 slot MV-1F - Long board similar to 1A MV-1T - Short board MV-1FZ - Short board with coin cell rechargeable battery MV-1FZSB - Similar to above MV-1FT - Similar to above MV-2 - 2 Slot, memory card, controller connectors, MVS wiring standard for stereo output MV-4 - First model 4 slot, same functionality as 2 slot MV-4F - Another 4 slot MV-4FH2 - Another 4 slot There may well be others, there's a ridiculous number of revisions of MVS Link to comment Share on other sites More sharing options...
Frank_fjs Posted April 4, 2018 Author Share Posted April 4, 2018 Thanks Sean! The main thing that affects the supergun re MVS is the audio. Not all MVS variants have a mono/stereo switch so I need to accommodate this. This is causing me grief as I've just incorporated composite video output along with audio out via RCA. Trying to get all possible scenarios to play nicely with each other is proving to be a headache. Mono out via DIN Bridged mono out via DIN (left/right stereo output to a single output) Bridged mono via left/right RCA True stereo via left/right rca. Snes adapters arrived today and work wonderfully. Opens the door up to standard snes controllers, wireless snes/xbox/ps/wii controllers via an 8bitdo wireless snes receiver. The latest supergun now has: Onboard negatron Voltmeter CPS1/2 kick harness support Optional video hat for composite video and mono/stereo audio output via RCA. Link to comment Share on other sites More sharing options...
Nimmers Posted May 2, 2018 Share Posted May 2, 2018 Can I put my name down for the next batch? Link to comment Share on other sites More sharing options...
Frank_fjs Posted May 2, 2018 Author Share Posted May 2, 2018 Most definitely! Still performing some final refinements, hoping to be ready soon. I'll attach some progress pics. Snes controller adapters are finalised. Supergun needs some minor tweaks. Video board is quite different to what's pictured here. Spaced the RCAs more sensibly apart, have added an s-video socket. Composite video is working great barring some dot crawl which I can't seem to eliminate. S-video is absolutely flawless, gorgeous picture. Link to comment Share on other sites More sharing options...
NEO-GEO Man Posted May 2, 2018 Share Posted May 2, 2018 Most definitely! Still performing some final refinements, hoping to be ready soon. I'll attach some progress pics. Snes controller adapters are finalised. Supergun needs some minor tweaks. Video board is quite different to what's pictured here. Spaced the RCAs more sensibly apart, have added an s-video socket. Composite video is working great barring some dot crawl which I can't seem to eliminate. S-video is absolutely flawless, gorgeous picture. What chip are you using for the compost video Frank? Have you tried a CXA-1645? That is what Namco used on their breakout boards for their 50" machines, im not sure why they didnt just use RGB like Sega did, but i did have a Namco board laying around at home years ago. Link to comment Share on other sites More sharing options...
Frank_fjs Posted May 2, 2018 Author Share Posted May 2, 2018 I'm using the CXA2075. More modern and requires fewer external components. Link to comment Share on other sites More sharing options...
NEO-GEO Man Posted May 2, 2018 Share Posted May 2, 2018 I'm using the CXA2075. More modern and requires fewer external components. Yeah i wonder if that is why youre getting the dot crawl? Ive not seen that on 1145s or 1645s, but then its been years since ive used composite video too. Link to comment Share on other sites More sharing options...
kryptonyte Posted May 2, 2018 Share Posted May 2, 2018 Awesome work. Great job with the ongoing refinements and additional features. Always nice to see some locally developed products. Please put me down for a Sentinel board and a couple of SNES adapters when the next batch is ready for release. Frank, which cheap mini ATX pico power supply did you use? Can you recommend an Aussie seller? Link to comment Share on other sites More sharing options...
Andyj965 Posted May 3, 2018 Share Posted May 3, 2018 Put me down for one from the next batch too please Link to comment Share on other sites More sharing options...
Frank_fjs Posted May 3, 2018 Author Share Posted May 3, 2018 Re the dot crawl, it's nothing out of the ordinary. I've noticed it on some Mega Drive consoles and other superguns. Just bothers me cos I'm a perfectionist. I will experiment with building an external trap filter. Have also improved the grounding so that may help. I did notice that the dot crawl reduced using a PAL oscillator however NTSC seems to be more compatible. Some arcade boards such as CPS1/2 don't play nicely with PAL, no idea why. Also I didn't have things connected optimally, was using test clips and hookup wire so perhaps in the revised pcb with a proper connection this will help. Re the mini ATX, I grabbed mine from Aliexpress. I used an external hard drive PSU to power it as it had the right connector and plenty of grunt. You want at least 2 Amps, preferably more if you can manage it. For the pico, I'd suggest 250 Watt as a good minimum. With the new design it caters to 24 pin ATX as well. Still a 20 pin connector however there's now room for a 24 pin plug to dock with the extra 4 pins sitting to the side. eBay has the picos if you don't like Ali. Link to comment Share on other sites More sharing options...
con Posted May 3, 2018 Share Posted May 3, 2018 Hiya How does the video board pictured work with the supergun is it integrated? Will you consider providing rgb video out screw terminals on supergun making it easy to hookup an arcade monitor? Definitely interested in all Link to comment Share on other sites More sharing options...
Frank_fjs Posted May 3, 2018 Author Share Posted May 3, 2018 The video board is a hat that sits on top. Attached a crappy pic as a loose demonstration. There's exposed pads on the video board for raw unprocessed signals of RGBS as well as power and audio. The sgun spits out RGB scart via DIN. I'm thinking of changing the current Neo Geo style DIN to Mega Drive 2, 9 pin mini DIN. The connector is more compact and allows for stereo sound. Link to comment Share on other sites More sharing options...
Frank_fjs Posted May 3, 2018 Author Share Posted May 3, 2018 This is the PICO I purchased. $20 landed from Aliexpress. It's 120W and outputs 4A on the +5V line. 1109 DC ATX PSU 12V 120W Pico ATX Switch Pico DC-DC PSU 20pin MINI ITX DC to ATX PC Power Supply For Computer http://s.aliexpress.com/i67jeaIF Output voltage was fine for what I threw at it, Neo Geo/Capcom/System16/PGM/Atomiswave etc. If you want more power, you can spend more money and grab a 24 pin PICO with more grunt. Link to comment Share on other sites More sharing options...
Plasia Posted June 13, 2018 Share Posted June 13, 2018 I'm mega pumped for this, I want 4! Link to comment Share on other sites More sharing options...
Frank_fjs Posted June 13, 2018 Author Share Posted June 13, 2018 Thanks man! Had the boards shipped via EMS so hoping they land this week. Link to comment Share on other sites More sharing options...
klee123 Posted June 14, 2018 Share Posted June 14, 2018 Interested in one. Link to comment Share on other sites More sharing options...
wyldcat34 Posted June 14, 2018 Share Posted June 14, 2018 Woohoo! Thanks man! Had the boards shipped via EMS so hoping they land this week. Link to comment Share on other sites More sharing options...
Frank_fjs Posted June 14, 2018 Author Share Posted June 14, 2018 They made it to NSW today, fingers crossed AusPost gets them to me tomorrow. Link to comment Share on other sites More sharing options...
AlxUnderBase Posted June 25, 2018 Share Posted June 25, 2018 Thanks for your awesome work ! Link to comment Share on other sites More sharing options...
Frank_fjs Posted June 25, 2018 Author Share Posted June 25, 2018 Thanks man. Getting there, I keep making refinements which holds things up but I'm just about there. Couple of tweaks for the composite video circuit and I'm done. Link to comment Share on other sites More sharing options...
NEO-GEO Man Posted July 2, 2018 Share Posted July 2, 2018 Thanks man. Getting there, I keep making refinements which holds things up but I'm just about there. Couple of tweaks for the composite video circuit and I'm done. Ive built mine but have not had time to test it yet. Link to comment Share on other sites More sharing options...
NEO-GEO Man Posted December 14, 2018 Share Posted December 14, 2018 Thanks man. Getting there, I keep making refinements which holds things up but I'm just about there. Couple of tweaks for the composite video circuit and I'm done. Frank how are you going with all this mate? If you need someone to assemble items for you let me know, ive got all the gear and a bit more free time at the moment. Link to comment Share on other sites More sharing options...
