Powder coating cost?
sparkaruss
thinking about getting legs ,rails ,lockdown bar,coin door surround and a couple of other bits powdercoated on a data east. has anyone had it recently done ,that could give me a rough idea what im looking at ? thanks
$300-350
Ive had several sets done in geebung qld ive never paid more than 150 hinges legs everything also do the leg bolts anf the hinge pivot bolts and do spares for the legs as taking the legs on and off can knock to power coat on the bolts around
You can powdercoat over old PC as long as it s in ok cond not flaking but not over "wet" paint as in the paint from a can
old legs as long as surface rust is removed and no flaking of the existing finish
I had a set of four Bally legs sandblasted for $25 locally, then dropped them around the corner for powder coating in satin black for $55 last week.
I was happy with that price :)
I have had quite a bit of it done in the last year and for 4 x legs, 2 x rails, LD bar, 2 x hinges and coin door & surround - I pay $90-$120, but anything up to $150 I guess is reasonable. Electro chrome plating is a lot more expensive. One very important thing to remember is that the coin door surround is generally not the same metal as the door, so make sure you inform the powder coaters as they may heat treat it to strip off the existing paint/rust. Look what happened to mine:
I think the surround must be aluminium or similar as opposed to cast metal door.
$300-350
Yours are often the 2 process for metallic hence the higher price i think Simon? They really do come up that bit extra special.
[ATTACH=CONFIG]112658[/ATTACH]
That is correct, you must advise the powder coaters if you are going to do the entire coin door that the surround is aluminium. That looks really sad Glen!
Don't you just love Diecast
Ive been quoted $380 to strip, sandblast and prime then quoted $180 for powder coating. These are new stern legs, rails, lockbar, backbox.
They say it needs to be primed etc due to the apperance of the stern metal materical. Powder coating onto it will not make them look smooth and may chip easy.
Thought ?
- Con
Thought ?
- Con
There seems to be different thoughts on this Con from the powder coaters themselves. Some prep and go straight over. The powder coat builds up in the grain and they come out almost smooth. Some insist it needs to be removed?
If it a 2 step process like i have seen on @KISS machines by the time the second process occurs it is a nice even coat.
The same applies to 2pak painting them. I had mine done here in our paint shop and all i had to do was a light sand to remove the MR Sheen build up :lol and then the primer all but fills the grain and by the time the 4th coat of clear went on they were mirror finish and tough as nails.
These were NOT rubbed back smooth
[ATTACH=CONFIG]112667[/ATTACH]
Edited by JOKERPOKER
Nice thanks for the idea Scotty!
I can paint em in 2 pac and prep the suckers for much cheaper and thats what I used to do back in the days.
Im going to go down there where I have beem quoted these prices to shown them exactly whats going on. Otherwise if they are going to pre them might as well chrome the suckers so that I cam wear a glove when playing like you 😂
- Con
It was. They took the piss out of me too. How the hell was I meant to know it was aluminium? ha ha.
I was just very lucky I was able to source another surround close by.
That's a bugger. Thanks for the heads up. I've got to take a pile of parts in and wouldn't have even thought about it.
BTW I think you've got something stuck in your beard 😁
Ha ha, thats not me with the beard! If I had a beard, Mrs would never touch me!
- Con
If you don't mind, where did you get the quote?
Have you tried TTG?
https://www.yellowpages.com.au/sa/para-hills-west/ttg-restorations-12036293-listing.html
or Southern Powder Coaters?
http://southernpowdercoaters.com.au/
I know TTG do the prep and powdercoating
Southern may be a bit cheaper than TTG but I don't know if they prep or strip.
Thanks for the links, the one out South I spoke to him a long time ago and he knew his stuff. Ill head down that way and show them what I want and how to best achieve a finish without spending to much cash.
Ill buzz the other mob and go from there. If its gonna be preped then I may as well get it chromed.
Have you used any of these guys yourself ?
- Con
- Con
Have used TTG for work but I didn't have to pay the bill :) but they did a quality job.
My brother in-law's work uses Southern's regularly but I haven't personally, from what he has said they are competitive
Ah righteo, TTG is near me so that could be a start and then ill check out Southern. Delway was pricey however im sure they also do quality. Powder coating is not expensive its the prep work. Dam you pinball machine but I love you 😊
- Con
This is what Delway has quoted me sheesh, it costs this much to powder coat a stern pin ?
We can offer you the following **
1 x lock bar
2 x side rails
2 x back box plate
4 x legs*
Prices for 1 set only
To strip and powder coat in Dormant Purple $780 including gst*
To chrome plate above pieces $1430 including gst
- Con
