poidapoida Posted June 15, 2016 Share Posted June 15, 2016 (edited) I picked up this Hankin 20 inch cocktail off of @feeras in Feb this year. Don’t see them come up too often so didn’t hesitate to grab it. It’s in fair condition, needs a quite a bit of work cosmetically, but all least it’s all there. http://i.imgur.com/yQK1ziX.jpg http://i.imgur.com/v73K2yj.jpg http://i.imgur.com/RY1tH05.jpg http://i.imgur.com/vk2y7LX.jpg http://i.imgur.com/vk2y7LX.jpg http://i.imgur.com/hTzozJG.jpg Was planning to put it away as a future project, have some major renos planned and bub no.2 on the way..... So 4 weeks later on a Sunday arvo I stripped it :lol http://i.imgur.com/tF7Ab8M.jpg http://i.imgur.com/XJoUhBa.jpg http://i.imgur.com/PkgjsQt.jpg http://i.imgur.com/GVmiSVl.jpg http://i.imgur.com/QapdCTH.jpg I want this to have the original look on the outside and luckily have all parts to do this. Internally, happy to reuse parts and update others as needed. The biggest issue for me was the water damaged/swollen MDF. I didn’t want to remake any panels, after a bit of research I settled on using wood hardener. The worst damage was on the base so it was a good place to test it. Firstly I pulled the layers of MDF off in the swollen areas until it was nearly level with the rest of the panel. Secondly I sponged a fair bit of the hardener on , not quite soaking it, did this twice with a gap of couple of days and left for a few days. Probably left more time than need between steps but I was in no hurry. The hardener did cause the MDF did swell a little bit but after setting it was probably 75% “less spongy”, so pulled a few more layers off gave it another coat and than a sand. I was happy with the result so went onto the rest of the cab. So I used the hardener on all cut edges, swollen and damaged MDF. Then builders bog to repair the chunks taken out the door and other damage. Sanded off all the vinyl that was on the cab and it ended up pretty good. I decided to go with paint as a finish as it would hid the imperfections, where vinyl would highlight them. http://i.imgur.com/xHGuS3W.jpg http://i.imgur.com/QSDpKAq.jpg http://i.imgur.com/1Xb3eNY.jpg http://i.imgur.com/mTDYIiZ.jpg http://i.imgur.com/1QBV5sZ.jpg http://i.imgur.com/Spl63UC.jpg http://i.imgur.com/TsDuGRZ.jpg Sent off parts for powder coating, glass clip, top hinges, coin box, CP bases, legs, speaker grille and coin mech surround. It would have taken me weeks just to clean the rust off of then myself, so was happy with $150 it cost and get them back in a couple of days. Would be interested to know how that price compares as it was my first time powder coating parts. Also ended replacing the original monitor as the chassis was shot, couldn’t easily find a replacement and then had no way to test the tube. After a couple of orders came in I was ready to start to reassemble. Cleaned and tested the original switch, emi filter and transformer. Put in a new PSU, coin mech, speaker, fan, t moulding and a unused Jamma harness that came with the cab. http://i.imgur.com/LfrayeJ.jpg http://i.imgur.com/aF1xQQW.jpg So next, I am waiting on a package from Noodleshirt . New control panels, Hankin glass border and a couple of Bomb Jack instruction cards! Edited June 15, 2016 by poidapoida fixed images Link to comment Share on other sites More sharing options...
BIG Trev Posted June 15, 2016 Share Posted June 15, 2016 Looking great. I can't wait to see it finished. Link to comment Share on other sites More sharing options...
poidapoida Posted June 15, 2016 Author Share Posted June 15, 2016 Looking great. I can't wait to see it finished. You asked me earlier this year what I would think the chances putting a few PCBs and a jamma switcher in one of these. I am going to stack two boards on top of each other on the door but without a switcher. If you had a smaller board you could probably fit it on top of the coin box. As big as these look I was surprised to find out that the top is the same size a 14 inch LAI cocktail Link to comment Share on other sites More sharing options...
Homepin Posted June 15, 2016 Share Posted June 15, 2016 Great job, I wouldn't have the patience to do things like this these days so more power to you for resurrecting an Australian classic! Link to comment Share on other sites More sharing options...
poidapoida Posted June 19, 2016 Author Share Posted June 19, 2016 Great job, I wouldn't have the patience to do things like this these days so more power to you for resurrecting an Australian classic! Thanks! I am doing this one as a keeper, but compared to the proper restoration threads they are the ones with patience. Link to comment Share on other sites More sharing options...
poidapoida Posted July 6, 2016 Author Share Posted July 6, 2016 (edited) Got around to finishing off the wiring today and was hoping complete the t moulding but have hit a snag. http://uploads.tapatalk-cdn.com/20160706/9d4da32b7c47c50598eca893ad99f86b.jpg The moulding on the right side was a bit loose on one end but was sorted by adding a strip of tape to the tongue and gluing it in. But the left hand side slot is totally stuffed. MDF panel is a bit swollen and the slot is now way to wide and spongy to hold the t moulding. I am thinking i may have to use contact adhesive and clamp each section in place as I go. Not confident it will look great so if anyone has any other suggestions it would be appreciated. Sent from my SM-G800Y using Aussie Arcade mobile app Edited July 6, 2016 by poidapoida Link to comment Share on other sites More sharing options...
blockhead321 Posted July 7, 2016 Share Posted July 7, 2016 Maybe you could just pack out the slot a bit with some thin packing wood or you could bog and harden up the swollen mdf and sand it back down where its swollen and then cut new slots for t moulding alot of work though Sent from my GT-I9505 using Tapatalk Link to comment Share on other sites More sharing options...
poidapoida Posted July 12, 2016 Author Share Posted July 12, 2016 So went with gluing and clamping. Used Tarzan's Grip sparingly and clamped each section seperately. Turned out well except in one spot that I applied to uch pressure and the t-mould is flat. I alsoran around the edge of the mdf with a black nikko so the swollen mdf panel wouldn't be so obvious. http://i.imgur.com/aL92QFR.jpg http://i.imgur.com/i2mWFmt.jpg Picked up the control panels that have been powder coated in crinkle finish. http://i.imgur.com/d1lW9kQ.jpg http://i.imgur.com/v8V7bi3.jpg So have some art on the way from Noodlshirt. Repro CPOs, Bombjack instruction cards and Hankin vinyl glass sticker that should finish this off nicely. Link to comment Share on other sites More sharing options...
poidapoida Posted July 31, 2016 Author Share Posted July 31, 2016 (edited) Got around to completing the Hankin today. I am really happy with the finished result. That art came from @MamePatrol during the week. Looks good as usual especially the control panels. http://i.imgur.com/lveQpDZ.jpg http://i.imgur.com/aD6gECg.jpg Attached the control panels and wired up the controls. http://i.imgur.com/PIXXKva.jpg http://i.imgur.com/KmMx5j0.jpg It was the first time applying a vinyl decal and used the wet method for the glass underlay and had no issues. So time to put the top together. I was going to put Bomb Jack instruction cards in but in the end preferred the clean look so went with just the insert coin print. BEFORE http://i.imgur.com/5sdpglA.jpg AFTER http://i.imgur.com/z8nRY1r.jpg http://i.imgur.com/DRfLMmk.jpg http://i.imgur.com/mFGtr3s.jpg http://i.imgur.com/1m1PJ8r.jpg http://i.imgur.com/eOUmOmp.jpg http://i.imgur.com/Qm1kjqX.jpg Once I wire up a harness for Bomb Jack I'd like to fit that in with Time Pilot and play the hell out of those two games. Edited July 31, 2016 by poidapoida Link to comment Share on other sites More sharing options...
blockhead321 Posted July 31, 2016 Share Posted July 31, 2016 Looks great mate good job Sent from my GT-I9505 using Tapatalk Link to comment Share on other sites More sharing options...
Davefjedi Posted July 31, 2016 Share Posted July 31, 2016 Where did you get the CP with the artwork on them from ? Link to comment Share on other sites More sharing options...
poidapoida Posted July 31, 2016 Author Share Posted July 31, 2016 Where did you get the CP with the artwork on them from ? Noodleshirt mate. Sent the originals to him and he did the rest Sent from my SM-G800Y using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
BIG Trev Posted July 31, 2016 Share Posted July 31, 2016 That's fantastic. Congrats on the beautiful restoration. I want one. Link to comment Share on other sites More sharing options...
MamePatrol Posted July 31, 2016 Share Posted July 31, 2016 Now that's a quality resto! What a great looking cab! Well done. :) Link to comment Share on other sites More sharing options...
Roxbury Posted July 31, 2016 Share Posted July 31, 2016 Well done, looks great Link to comment Share on other sites More sharing options...
gottaconnect Posted July 31, 2016 Share Posted July 31, 2016 niice work. It looks great Link to comment Share on other sites More sharing options...
Rich Posted July 31, 2016 Share Posted July 31, 2016 Has come up a treat :023: ...been a long time since I played last and I too loved bomb jack and I could be wrong but he moves diagonally doesn't he?...curious to know did Hankin do control panel artwork for 8 way controls? Link to comment Share on other sites More sharing options...
Davefjedi Posted July 31, 2016 Share Posted July 31, 2016 @noodleshirt would you be able to make another setup ? and what cost ? Link to comment Share on other sites More sharing options...
poidapoida Posted August 1, 2016 Author Share Posted August 1, 2016 @noodleshirt would you be able to make another setup ? and what cost ? @MamePatrol see above Link to comment Share on other sites More sharing options...
markandsophie Posted August 1, 2016 Share Posted August 1, 2016 can i ask about the top glass? Did you buy the glass then get the black outline printed on it? I also have a 20 inch same as yours that ill restore. Thanks for sharing your work Mark Link to comment Share on other sites More sharing options...
poidapoida Posted August 1, 2016 Author Share Posted August 1, 2016 can i ask about the top glass? Did you buy the glass then get the black outline printed on it? I also have a 20 inch same as yours that ill restore. Thanks for sharing your work Mark That's a vinyl sticker applied to the back of the glass. I gave measurements and a pic of a tabletop that i wanted to Noodleshirtand he made it up. So its not original but pretty close. And i just used the glass that was with the table as it was in good nick. Sent from my SM-G800Y using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
MamePatrol Posted August 4, 2016 Share Posted August 4, 2016 @noodleshirt would you be able to make another setup ? and what cost ? Absolutely mate, send me a PM or email and I'll see what you need. :) Link to comment Share on other sites More sharing options...
poidapoida Posted February 8, 2022 Author Share Posted February 8, 2022 @BullClip These should be most of the photos that are missing mate. Hit me up if you need any more. 2 Link to comment Share on other sites More sharing options...
baz Posted February 8, 2022 Share Posted February 8, 2022 59 minutes ago, poidapoida said: Control panels look amazing , how can i get a set for myself ? Link to comment Share on other sites More sharing options...
poidapoida Posted February 8, 2022 Author Share Posted February 8, 2022 41 minutes ago, baz said: Control panels look amazing , how can i get a set for myself ? Noodleshirt did the vinyl overlays. 1 Link to comment Share on other sites More sharing options...
