OZ stick bent my pins
tristancg
i ordered a joystick and some buttons from http://www.ozstick.com.au/ and a was ecstatic when they arrived (they arrived really fast) i opened the box the see that all of the buttons where shoved in the box with the stick and the pins on the stick where bent :damnit:
i contacted them and they said that they meant to do that and to just bend it back
I HATE BENT PINS and bending them back weakens them
what should i do other than complaining online?
i have a picture of the damage
If this is a serious question, then: +1 don't waste your time, or OzStick's time.
Completely normal. slightly bent the leg straight if you're that worried. If you do it back and forth multiple times then of course it will snap. But as a once off, and gently to a somewhat straighter position, will be perfectly harmless.
