Forum Updates
Arcade King
26 minutes ago, kayakkingoz said:
I just tried to edit a reply that I sent & edited earlier. Now edit option will not come up.
Nice work on the new site. 👍
There is a timer on Post Edits so we don't get content removed/deleted. Once the timer elapses no more edits. This was also a thing on the old forums.
Installed a mod that will automatically show users country flag so old text field is now removed.
I'm also thinking about this
Create a discussion topic for new calendar events. Allowing your community to discuss events. Click here to read my IPS Marketplace purchase guide before purchasing.
Features
  • Decide which forum will be used for each individual calendar.
  • Choose a fixed member as topic author or use the event submitter as author.
  • Edit the contents of the topic with quick tags that support details like the event date, title or submitter.
  • Discussion topics will be edited, hidden or approved when ever an event is edited, hidden or approved.
  • Hook adds a link to the discussion topic for events which have them.
This will allow the user to put a event in the calendar and automatically create a thread.
Thanks for that.  I don't always use a VPN but must have been at the time that the forum polled my IP.  I'm not now and it thinks I'm still USA.
The "country" tab in account settings is just a toggle for flags, not a manual country setting.
Changes aren't always instantaneous and usually work in cron jobs or tasks.
That's odd because mine has a list of all Countries, maybe an Admin thing.
8 minutes ago, Reefwalker said:
thanks... I best go and donate some money and become one of the special group 🙂
People with 20 posts and have been a member for 30 days move to full member so you must be close.
this be 21 😉
Maybe all that activity stream setup I did will work now too
Edited by Reefwalker
Had a report yesterday from an AAer that his topics weren't showing up in search and in " Content I Started".
Rebuilding the search seems to have solved the issue however curious if anybody else encountered this.
I'm currently looking at the Classifieds app to see if its a good fit for us.
Just installed this update
IPS Community Suite 4.6.6
Released 09/08/2021
Key Changes
This is a maintenance release for Invision Community 4.6.
Additional Information
Core
  • Improved catching errors that 3rd party hook may throw.
  • Added grouping to approved content push notifications.
  • Changed lost password reset links to be valid for 1 hour.
  • Upgraded CKEditor to 4.16.2.
  • Fixed some missing language strings in Member History when looking at badges/points.
  • Fixed an issue with the SQL toolbox pagination when a table prefix was being used.
  • Fixed an issue where achievement excluded groups still show in the widgets.
  • Fixed an issue where required profile fields may be skipped from profile completion.
  • Fixed an issue where it was not possible to post status updates if the ability to follow a member was disabled.
  • Fixed an issue where videos attachments that are not supported by a browser may not be downloadable.
  • Fixed an issue where some admin control panel profile blocks could show if the features were disabled.
  • Fixed an error when a restricted admin attempted to add moderators.
  • Fixed an issue where following a member can send a notification if you choose to follow anonymously.
  • Fixed an issue where a view update task may attempt to connect to Redis when Redis is not used.
  • Fixed an issue where search statistics in the ACP can be slow to generate.
  • Fixed an issue where the 'follow member' achievement rule didn't calculate milestones correctly.
  • Fixed an issue where WebP may be shown as an accepted extension when not fully supported by the server.
  • Fixed editor becoming unresponsive when inserting attachments into the editor.
  • Fixed an issue where an automatically deleted notice may be shown on a member in AdminCP but the account isn't queued for deletion.
  • Fixed an issue where a failed file move could delete the filenames of Reactions.
  • Fixed an issue with the REST API where it may be possible for hidden comments to be seen.
  • Fixed a minor typo when processing an RSS import.
  • Fixed an issue where the AdminCP member list may be slow to load.
  • Fixed an issue where saving changes to an Easy Mode theme might fail due to an error.
  • Fixed an issue where the health dashboard error log chart may not be accurate.
  • Fixed an issue where Achievements notifications loaded via the REST API may be attributed to a guest.
  • Fixed social login buttons not working on the register form when using quick registration.
  • Fixed an error being generated when viewing Member history.
  • Fixed the group search flood control setting not showing the correct value.
  • Fixed an issue where search pagination can lose quick search and node parameters.
  • Fixed issue where the AdminCP Search Activity statistics restriction wouldn't cause a corresponding in the menu to appear.
  • Fixed an issue where the 'solutions' table on a members profile would not paginate.
  • Fixed an issue where content controllers wouldn't find comments that are archived and stored in a separate archive database.
  • Fixed an issue where the new rank mobile notification throws an error.
  • Fixed an issue in the Achievements Rebuild Routine which would result in an exception while the rebuild.
  • Fixed an issue where creating a member moderator with a visible badge could break the view.
  • Fixed an issue sending a push notification when a new badge is earned.
  • Fixed an issue where created_externally flagged accounts may be deleted when awaiting validation, where it may be desirable to keep them.
  • Fixed an issue where the widget data weren't updated while application upgrades.
  • Removed few occurrences from the in 4.6 removed notification sounds setting.
  • Fixed an issue with the AdminCP menu manager not displaying dropdowns in some situations.
Downloads
  • Fixed an issue where a large file description may not save if it is larger than 64kb.
  • Fixed the group wait time setting not showing the correct value.
  • Fixed an issue re-activating a purchased file if the original invoice or currency does not exist.
Forums
  • Improved performance of hiding/unhiding/deleting topics.
  • Fixed an issue where not all forums could show when creating topic and post feed widgets.
  • Fixed an issue where archived posts aren't counted towards a member's total post count
Calendar
  • Fixed an issue where weekly recurring events with no end date could display one day off.
  • Fixed birthdays not showing on the initial Calendar view when only one calendar is present.
  • Fixed an issue where rare badges calculated with all members, and not just those permitted to use achievements.
Pages
  • Fixed an issue where the topic sync background task may get stuck in a loop.
  • Fixed an issue where category edit permissions would override the moderator edit permission.
Converters
  • Fixed an issue running a conversion on PHP 8.
  • Fixed an issue where long group username styles in Xenforo could cause a database error.
Gallery
  • Fixed an issue upgrading from a really old version of Gallery.
Commerce
  • Changed new PayPal subscriptions to not collect previous period charge on next cycle if the previous cycle failed.
  • Fixed a database error caused by long shipping service names.
  • Fixed an issue where the CVC/Address/ZIP checks were unavailable on Stripe payment intents in the AdminCP.
  • Fixed an issue where upgrading to a package with a longer initial term would not extend the expiry date.
  • Fixed an issue where deleting a product filter wouldn't delete all the language strings.
  • Fixed an issue where Google/Apple/Microsoft pay transactions would show a red 3DSecure error on transactions.
  • Fixed a PHP 8 specific issue that could cause an exception when viewing a product with reviews.
  • Fixed an issue where Stripe JS may be loaded more than once.
  • Fixed an issue where it was possible to receive multiple subscription free trials.
Changes affecting third-party developers and designers
  • When building applications on Windows, Javascript/Themes imports will use \n line endings.
  • Fixed an issue editing hooks IN_DEV when using PHP 8.
1 hour ago, Bionic Rooster said:
I find it odd that with the developer staff they have that IPS has so many bug fixes after the last release. I expect that with platforms that have fewer devs.
Its agile development methodology. All the big players generally use it these days. I mean Microsoft? Look at PC and Console games. I'm surprised your surprised 🙂
After VB5 its a relief to see development is ongoing.
  • Haha 1
15 hours ago, Rich said:
am i missing something, which i expect, but have post numbers been removed?
i am wanting to reference a certain post but cant find the #?
I haven't seen any post numbers in the new software.
Just go to the post you want to share
Click on this icon and select "share" then cut and paste the provided URL into your post.
For Example here's the link to your post above
