NRI coin mech issue?
skitz
howdy guys, I have a coin mech in Demolition man but it will only register the $1 coins and not the $2 coins. However if I take the coin mech out and put it in another machine with the same wiring harness, the $2 works?:unsure:unsure so I swapped out the boards inside the door, same issue. Both machines are set to "Australia 1" price setting as well. So I guess there is something wrong with my wiring on Demo man. I have looked and all the wires seem to be in place. any suggestions as to where I can start looking? thanks
3 answers to this question
do you mean it has the same type of harness? or that you used the same cable? are you using a ribbon to j4? the same ribbon ? whats the other machine that works?
the other machine I plugged I into is roadshow. I used the same ribbon cable from demo man coin mech and plugged it into j6 on the roadshow board. thanks
