Prof Posted October 28, 2006 Share Posted October 28, 2006 To stop all the people asking what the pinout of such and such :) VGA analogue display connector Pinout 1 Red out 2 Green out 3 Blue out 4 Monitor ID 2 in 5 Ground 6 Red return 7 Green return 8 Blue return 9 no pin 10 Sync return 11 Monitor ID 0 in 12 Monitor ID 1 in 13 Horizonal Sync out 14 Vertical Sync out 15 reserved (monitor ID 3) RGB analogue display connector Pinout Used on atari and amiga style monitors. For comp sync, used the H Sync input PinFunction1 Ground2 Ground 3 Red 4 Green 5 Blue 6 N/C 7 N/C 8 H-Sync 9 V-Sync Link to comment Share on other sites More sharing options...
0 MadMikeAU Posted October 28, 2006 Share Posted October 28, 2006 A few notes to add to the original post. VGA analogue display connector Pinout 1 Red out 2 Green out 3 Blue out 4 Monitor ID 2 in 5 Ground 6 Red return 7 Green return 8 Blue return 9 no pin (Named Composite Sync in the original standard, but modern monitors dont even have a pin here). 10 Sync return 11 Monitor ID 0 in 12 Monitor ID 1 in 13 Horizonal Sync out 14 Vertical Sync out 15 reserved (monitor ID 3) Link to comment Share on other sites More sharing options...
0 serviceit Posted July 6, 2008 Share Posted July 6, 2008 Jamma Pin out SOLDER SIDE PIN PIN PARTS SIDE GND A 1 GND GND B 2 GND + 5V C 3 + 5V + 5V D 4 + 5V - 5V E 5 - 5V +12V F 6 +12V KEY H 7 KEY COIN COUNTER 2 J 8 COIN COUNTER 1 K 9 SPEAKER (-) L 10 SPEAKER (+) AUDIO (GND) M 11 AUDIO (+) VIDEO GREEN N 12 VIDEO RED VIDEO SYNC P 13 VIDEO BLUE SERVICE SWITCH R 14 VIDEO GND S 15 TEST SWITCH COIN SWITCH 2 T 16 COIN SWITCH 1 START SWITCH 2 U 17 START SWITCH 1 2P UP V 18 1P UP 2P DOWN W 19 1P DOWN 2P LEFT X 20 1P LEFT 2P RIGHT Y 21 1P RIGHT 2P PUSH 1 Z 22 1P PUSH 1 2P PUSH 2 a 23 1P PUSH 2 2P PUSH 3 b 24 1P PUSH 3 c 25 d 26 GND e 27 GND GND f 28 GND Link to comment Share on other sites More sharing options...
0 coolspot Posted July 6, 2008 Share Posted July 6, 2008 this makes more sense http://members.iinet.net.au/~getderrick/JammaHarnessLabelsAZcorrectedFINAL2.jpg Link to comment Share on other sites More sharing options...
0 baz Posted September 17, 2010 Share Posted September 17, 2010 scart tv pinouts :) http://www.hdcabling.co.za/images/SCART_Pin_Layout_Diagram.gif Link to comment Share on other sites More sharing options...
0 channelmaniac Posted April 28, 2020 Share Posted April 28, 2020 Here's the pinout for the custom chip U99 on the Midway Y-Unit boards. I pinned it out painstakingly while working on a Trog board that showed a U99 error - with a good chip. Hope it helps! Link to comment Share on other sites More sharing options...
0 channelmaniac Posted December 3, 2020 Share Posted December 3, 2020 (edited) Here's the pinout for the 054538 custom from Konami, as used on an X-Men PCB. There are a lot of unused pins in this application that might be used elsewhere. Here's the circuit connections for the 054539 custom as used on the X-Men PCB. If you have damaged traces or corrosion damage, this should help you fix the game.. Edited December 4, 2020 by channelmaniac Minor edit to fix 3 pins... Link to comment Share on other sites More sharing options...
0 channelmaniac Posted December 4, 2020 Share Posted December 4, 2020 Here's the X-Men 054544 hybrid module's circuit connections. I pinned this out while repairing an X-Men with ripped traces from under the hybrid. Hope you find it useful! Link to comment Share on other sites More sharing options...
0 channelmaniac Posted December 22, 2020 Share Posted December 22, 2020 PC080 and PC090 from Taito. Found mistakes in the schematic with regards to the pinout. The pinouts I have here are from the schematics, but 2 changes were made to the PC080 by me, verified by my multimeter. SCA12 is on pin 73, not 43 MD3 is on pin 49, not 79 They have REALLY odd spiraling pinouts... Hard to wrap your head around until you see it documented like this... Link to comment Share on other sites More sharing options...
0 channelmaniac Posted Tuesday at 04:28 AM Share Posted Tuesday at 04:28 AM Here are three Konami customs... The protection custom was reversed using my multimeter and a PCB. The other two were pulled from partial schematics of Vendetta. I'll be posting more as we need to get these chips documented better in the community. 054538 - Protection custom from Sunset Riders 053260 - Sound custom on TiT 053251 - Graphics mux chip from Simpsons, Vendetta, and X-Men 2 2 Link to comment Share on other sites More sharing options...
Prof
Pinout
1 Red out
2 Green out
3 Blue out
4 Monitor ID 2 in
5 Ground
6 Red return
7 Green return
8 Blue return
9 no pin
10 Sync return
11 Monitor ID 0 in
12 Monitor ID 1 in
Pinout
9 answers to this question
