Fish Tales - Williams
Title : Fish Tales
Manufacturer : Williams
Year : 1992
Quote from Tony at The Pinball Shed :
Worked on 8 of these in the past year. 4 had a broken belt that drives the ball locking reel on the left handside. You need to remove this assembly from underneath, bit of a tricky one, just take your time. The belts are available here in Aust and are under $10.
The boathouse on the righthand side has a small single drop target that also seems to give a bit of trouble, underneath it drops down onto a switch and has a spring attached to flick it back. Have had to either adjust this switch or in some case replace it, spring also known to snap or jump off.
3 of these games also had the flapping fish topper not working, there is a coil behind the fish that causing the slapping effect. In all cases, a wire had come off the coil.
Overall a good family game, that is fairly reliable with not too many problem areas.
Edited by MrMaloo
Problems I have noticed.
Missing flapping fish and/or plastic bubble cover (often damaged). Missing pistol grip shooter handle, often substituted for a manual plunger or a large press button. Decals nearly allways faded, often one side worse than the other. Playfield wear around the large fish inserts, wear around the boat ramp. Little gate that opens for long cast (at top left of PF) often not working (activated by roll-over switch at top right if PF). Like Tony said reel belt needs to be kept good. Optos on reel need to be cleaned to maintain proper function. Bottom corners of slingshot plastics dont last long. All in all a very reliable machine really.
  • 10 months later...
Both plastics either side of the boat ramp get smashed, also the boat ramp plastic and both slings. Fit fender (mudguard) washers to all these places. Also blow a 240V surge protector on this machine, never done one before. :o
One of the most reliable games I've owned. Great family game, my kids love it. :D
+1 to the above probs. Apart from the parts missing thing (topper etc) both my FT have had broken belts,boat plastics,blue plastics on both sides of ramp,finicky caster house drop target adjustment,dirty optos esp.reel as greg said(they are hard to get to so a good chance no-one has ever cleaned them) and one had a broken leaf on the VUK but all in all apart from insert wear and cab fade never had an ongoing problem. My guess is with the amount of FT made and a pretty good reliabity it would have made a lot of money on-site.:)
  • 7 months later...
Problem with FT Reel
Hi - I am new to the site but have a problem with my recent purchase of a FT. Everytime you shoot a ball into the reel it pops it straight out again making it impossible to load 3 balls for multiball.
Appreciate some advice from anyone that has had this problem and/or may have solution. Cheers, Flipperage:D
Run the diagnostics from the menu - there is one that tests the reel and indicates the state of the optos - this may reveal your problem.
i had this problem last week. the switch on the x-over rail just b4 it enters the the reel had a wire break loose and was not registering the ball passing thru the switch which tells the reel to lock it. a dob of solder to replace the wire and all working again like it should have. check that switch for adjustment and/or wire adrift would be my suggestion.
  • 5 months later...
Yeah even when you start a new game it will often just shoot the first ball out without pressing the button.
Sounds like your button on the reel shooter could be stuck . It's a pretty common problem . Remove the whole shooter handle assembly , pull apart and give everything a good clean . If it's not the actual button that's stuck it could also be the switch directly under the button .
Rod 71, yeah Ive checked that one too thanks. Cruiser, the switch test for the button seems to be working but I guess it has to be a problem in there somewhere. I will investigate and report back if I find anything useful that someone else may use in the future.
My Fishtales has just been taken out of a ~4 year hibernation and I have no sound at all (amongst various other issues). Any suggestions on where to start with fault finding or pointing me to an existing resource.
Went through sounds self test and no errors but no sound for each sound bite.
Machine came up with factory settings as I guess the batteries ran flat.
Claude
Claude
Batteries probably leaked f you failed to remove them before storing it.
Edited by rod71
On power up, how many beeps are you getting?. Not to be confused with "bong bong bong" if there are switch errors etc.
I'm not getting any distinctive system generated beeps, just a bit of clicking or popping sound as soon as the pin powers up, then silence or just a low level hum.
I'm guessing the amp is gone, but could be wrong. Will try and figure out how to get line output to an external amp and test for sound.
Hmmm, you might be on the right track with the amp then. This is from pinrepair guide.
"No output at all.
The LM1875 audio amp is probably defective. This amp should have -26 volts
on pin 3, and +26 volts on pin 5. Anything else indicates a problem. The
sound ROM or RAM could be defective. There should be high pulses on the
output pins of the Sound ROM and RAM. The MC3340 attenuator can also
cause this problem."
