Super Moderator Foot Posted August 18, 2006 Super Moderator Share Posted August 18, 2006 Well I do believe the time has come to start breathing some life into my old (well aren't they all) LAI cocktail cabinet. I may have mentioned before that it runs a Gallag PCB and it is destined to stay that way. It's definitely had a hard life and the cabinet has suffered some water damage as well as it's share of knocks and bumps. I had been tossing up what to do with it, but the plan now is to restore to it's former glory. So the first stage of the resto will be the recon phase, where I'll pull it down and see what the damage is and compile a "Parts Wanted" list to ascertain what the wallet damage will be. While I'm at it I'll also measure and map out all the cabinet dimensions for use on a second cab to be built later down the track. So as always here's the before shots I'll keep you posted Link to comment Share on other sites More sharing options...
bwodie Posted August 18, 2006 Share Posted August 18, 2006 why do you love jason so much ? Link to comment Share on other sites More sharing options...
DKong Posted August 19, 2006 Share Posted August 19, 2006 Good to see LAI stuff. If you make plans for a second cab you might want to consider a 19 inch monitor, which will fit nicely :) Link to comment Share on other sites More sharing options...
RetroGame Posted August 19, 2006 Share Posted August 19, 2006 The LAI cocktail cabinets have only enough room for a 14 inch monitor if built to the exact same measurements of an original, you can fit a 15 inch in if you make some small adjustments to the control panel supports. As for a 19 inch, I think you would have to alter the dimensions of the whole cab. I am speaking from experience here as I have built many of these cabs. Link to comment Share on other sites More sharing options...
DKong Posted August 19, 2006 Share Posted August 19, 2006 The LAI cocktail cabinets have only enough room for a 14 inch monitor if built to the exact same measurements of an original, you can fit a 15 inch in if you make some small adjustments to the control panel supports. As for a 19 inch, I think you would have to alter the dimensions of the whole cab. I am speaking from experience here as I have built many of these cabs. thats cool just figured they might be the same cabinet size Link to comment Share on other sites More sharing options...
Administrators Arcade King Posted August 19, 2006 Administrators Share Posted August 19, 2006 Thats going to look fantasic! Good luck. Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted August 20, 2006 Author Super Moderator Share Posted August 20, 2006 Pulled the top off it and had a closer look. Hmm water damage is pretty bad on one corner and if you look at the table top you can see where water damage has occurred around where I've removed the class clip (its swelled so much it broke the laminate around the clip) Monitor surround has similar damage around 3 sides, appears it was stapled in position. I'm surprised I could see through the glass it was that badly scratched. So far looks like I'm up for replacing all the laminate sides, the top, glass and artwork, and monitor surround. Should get better from now on Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted August 28, 2006 Author Super Moderator Share Posted August 28, 2006 Well, the pic says it all. Stripped that little sucker bare. Boy they really didn't spend too much time on each unit when they whacked these together! There is about 2 reusable panels on the whole cab so I think I'll replace the lot. Still got some thinking to do about what the replacement panels will be made of. I've a pic in my head, just need to do some research into the finish Still got a few more measurements to take before I draw the plans to scale as well Before I attack the CP's I want to scan the "what ever the hell it is" artwork. I've got a Cannon iD35, don't know how well that will work. Anyway before the poor cab can go back together I've got to prep the Old Pajero for sale. Selling cars shits me. Oh well the replacement should be worth it, I'll grab a snap when we get it:D http://i153.photobucket.com/albums/s218/DerekFoot/cab8.jpg Link to comment Share on other sites More sharing options...
The Pinny Parlour Posted August 28, 2006 Share Posted August 28, 2006 nice work. good to hear your doing plans on the cab. that will be something I would love get. Link to comment Share on other sites More sharing options...
OzStick Posted August 28, 2006 Share Posted August 28, 2006 Hey foot, look me up for some Overlay to relaminate your cabinet once it's ready to do so. Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted December 29, 2006 Author Super Moderator Share Posted December 29, 2006 Okay, these are my plans for an LAI Cocktail cab with a 14" monitor. They are not CAD or anything fancy, just hand drafted (I use the term drafted very loosely) with a crappy pencil that won't scan well, hence the quality. Hope they are of some help. If anyone has the time to turn them into CAD feel free. LAI Cab Plans 1.doc LAI Cab Plans 2.doc LAI Cab Plans 3.doc I've also finished cutting and routing all the pieces for the cab. I'll post them later today. Here's a snap of the old mans workshop, makes cab building too easy http://i153.photobucket.com/albums/s218/DerekFoot/Shed.jpg Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted December 29, 2006 Author Super Moderator Share Posted December 29, 2006 Got all my bits and pieces pre sanded ready for assembly. The only original panel to be used will be the base. All the pieces are cut from a single 1800 X 1200 sheet of 18mm hoop pine furniture grade plywood. Ply came from "Brims" over at Yeerongpilly and cost about $85. The stuff is sold as seconds as it has slight thickness variances (less than 1 mm). The base is 12mm ply. http://i153.photobucket.com/albums/s218/DerekFoot/CabWood2.jpg Ikea Flat Pack http://i153.photobucket.com/albums/s218/DerekFoot/CabWood.jpg Spread out a bit I'll start putting it back together this weekend:D Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted January 6, 2007 Author Super Moderator Share Posted January 6, 2007 Been sticking bits together, pitures don't show how really stuffed the old chip on the cab was Old Cab http://i153.photobucket.com/albums/s218/DerekFoot/oldcab.jpg New Cab http://i153.photobucket.com/albums/s218/DerekFoot/newcab.jpg Hopefully by next weekend I'll have most of it all back together, t-moulding, cab exterior final workup etc. Still have to get new legs made (old ones are bent from excess weight being sat on the cab), some excess button holes in the cp's welded up.... shit, there's always something else to do Link to comment Share on other sites More sharing options...
danny_galaga Posted January 7, 2007 Share Posted January 7, 2007 very nice work (",) Link to comment Share on other sites More sharing options...
danny_galaga Posted February 4, 2007 Share Posted February 4, 2007 so hows it coming along? Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted February 4, 2007 Author Super Moderator Share Posted February 4, 2007 Slowly, needs to get get more t-moulding for the top, make new legs, powder coat, bla bla bla Heres a couple of pics. Sunlight makes it look lighter than it actually is. I ended up going for the stained looked as it will be in next to the pool table. It is just a shade lighter than the table so it should look good. http://i153.photobucket.com/albums/s218/DerekFoot/newcab1.jpg http://i153.photobucket.com/albums/s218/DerekFoot/newcab2.jpg Link to comment Share on other sites More sharing options...
LOTR4U Posted February 4, 2007 Share Posted February 4, 2007 Coming along nicely it seems to me :P Link to comment Share on other sites More sharing options...
danny_galaga Posted February 5, 2007 Share Posted February 5, 2007 ve'y niice!! http://us.i1.yimg.com/us.yimg.com/i/mo/borat_trailer250c.jpg Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted February 28, 2007 Author Super Moderator Share Posted February 28, 2007 It Lives!, got all the guts back in, up and running AOK http://i153.photobucket.com/albums/s218/DerekFoot/cabinside.jpg http://i153.photobucket.com/albums/s218/DerekFoot/cabintnew2.jpg http://i153.photobucket.com/albums/s218/DerekFoot/cabinside2.jpg Link to comment Share on other sites More sharing options...
Super Moderator WOKA Posted February 28, 2007 Super Moderator Share Posted February 28, 2007 Thats a funny looking pc..! ;) Link to comment Share on other sites More sharing options...
Crafty Posted February 28, 2007 Share Posted February 28, 2007 Very nice work.... Love the stained look.:D Link to comment Share on other sites More sharing options...
Johns-Arcade Posted March 1, 2007 Share Posted March 1, 2007 Nice job Foot, you've set everything out nicely. And you have picked the perfect game (Galaga) to go with it :) Regards, Johns-Arcade. Link to comment Share on other sites More sharing options...
Super Moderator Foot Posted April 7, 2008 Author Super Moderator Share Posted April 7, 2008 Still Going! got stuck on the back burner for a while but on track again now. Following from this thread about CP artwork here's the finished CP's CP's as I got them and tarted up ready for overlays http://i153.photobucket.com/albums/s218/DerekFoot/cp14-1.jpg http://i153.photobucket.com/albums/s218/DerekFoot/cppanels2-1.jpg Straight from the printer and trimmed up ready for application http://i153.photobucket.com/albums/s218/DerekFoot/CPprints1-1.jpg http://i153.photobucket.com/albums/s218/DerekFoot/cpprint3-1.jpg Player 2 and Player 1 overlays applied, with buttons and joysticks installed, wired up ready to go in the cab http://i153.photobucket.com/albums/s218/DerekFoot/cp7-1.jpg Installed in the cab, before and after http://i153.photobucket.com/albums/s218/DerekFoot/cp13-1.jpg http://i153.photobucket.com/albums/s218/DerekFoot/cp10-1.jpg I'm pretty happy with how this is turning out so far :D http://i153.photobucket.com/albums/s218/DerekFoot/cp11.jpg Hopefully it won't be a year before the next update! Link to comment Share on other sites More sharing options...
narf_ Posted April 7, 2008 Share Posted April 7, 2008 wow they come up a treat derek. Look alot better than when i found em was a shame there condition and the op drilling the hole (ive got the same on a dig dug overlay cp Link to comment Share on other sites More sharing options...
LOTR4U Posted April 7, 2008 Share Posted April 7, 2008 Woooowzerrr Nice! :d Link to comment Share on other sites More sharing options...
