Dedrok Posted May 24 Share Posted May 24 Pretty much am finished on the custom old pokie to arcade conversion. My mate did most of the early work, IE: Stripping the unwanted bits out and wiring up the power supply, plus doing all the decals. I just had to finish off wiring in the decent joysticks. Instead of just the one. I wired in a 2nd joystick so the are both wired the same. Got a good 4way to Replace the basic one, to play games that need it , especially Pac-Man. Then added a 2nd 8way to the other side. Once I worked out the most comfortable spacing with the mounting plate, I went ahead and cut it out, drilled countersunk holes for the bolts and started to make them fit. Once everything was worked out and fitted, then had to remeasure and mark out the Perspex panel cover to suit the layout. Then cut / shape it to suit and drill out the holes, being careful not to crack or split the Perspex. Used a 22mm wood bit and did halfway from each side. Worked out with no dramas. Then opened up the holes with a special tool to make them 23mm - 24mm for the switch buttons. Link to comment Share on other sites More sharing options...
Dedrok Posted May 24 Author Share Posted May 24 Once it was all shaped, the joysticks and buttons were fitted back in. Bit of a tight fit in a couple of spots but not too bad. Left to do is attach the Perspex , still deciding whether to place a few symmetrical chrome security bolts or use hidden attachments. Also some better generic buttons and 1 2 player starts, and some info decals for Starts, 4 way set, 8 way set all with the arrows, Fire/shoot, Bomb/Escape and whatever a 3rd button is Currently only running a 60 in 1, but that may change And that’s pretty much it for now 2 2 Link to comment Share on other sites More sharing options...
redferatu Posted May 24 Share Posted May 24 What is the ratio on that? With launchers you can load marquees at the top and instructions at the bottom, then run the game in the original ration. Might be worth looking in to as that looks a bit stretched and too be honest too big from so close. Otherwise it's a really interesting conversion. 1 Link to comment Share on other sites More sharing options...
Dedrok Posted May 24 Author Share Posted May 24 Yeah. That was my concern at first but I got used to it. I might look into it down the track. I was also thinking I may add Mame and some PinMame. The ratio looks perfect for a playfield size. 1 Link to comment Share on other sites More sharing options...
redferatu Posted May 24 Share Posted May 24 VPIN would look great on that 1 Link to comment Share on other sites More sharing options...
Autosteve Posted May 24 Share Posted May 24 Is it heavy like pokeys normally are? You've done well not to change it to much I think. It still looks like a pokey but lives another life. I like it. 1 Link to comment Share on other sites More sharing options...
Dedrok Posted May 25 Author Share Posted May 25 8 hours ago, Autosteve said: Is it heavy like pokeys normally are? You've done well not to change it to much I think. It still looks like a pokey but lives another life. I like it. Yeah it’s heavy but got that pokie look. Same with the touch juke next to it. Has that pokie look still. Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 25 Share Posted May 25 You could also include a MP3 Jukebox to it, giving it two personalities. Link to comment Share on other sites More sharing options...
Dedrok Posted May 25 Author Share Posted May 25 8 hours ago, Gemini2544 said: You could also include a MP3 Jukebox to it, giving it two personalities. Already done on the left one. Still going through naming corrections of around 1650 albums. 2 Link to comment Share on other sites More sharing options...
Autosteve Posted May 25 Share Posted May 25 36 minutes ago, Dedrok said: Already done on the left one. Still going through naming corrections of around 1650 albums. Yep video jukes are cool and I like Mp3 audio with a good visualization program as long as it has randomize. To much dramas organizing each and every song I want to hear. On 24/05/2023 at 12:34 PM, redferatu said: What is the ratio on that? With launchers you can load marquees at the top and instructions at the bottom, then run the game in the original ration. Might be worth looking in to as that looks a bit stretched and too be honest too big from so close. Otherwise it's a really interesting conversion. I'm interested in being able to do this. I think you are taking about displaying the game in 4:3 but using the remainder of the wide screen for game instructions and title header?. Link to comment Share on other sites More sharing options...
Railways Posted May 25 Share Posted May 25 Excellent Edy. It never ceases to amaze me how you guys can have an idea and make it all happen to look outstanding. 1 Link to comment Share on other sites More sharing options...
Crafty Posted May 25 Share Posted May 25 good job and looks great, Love the jukebox as well. Games rooms need music. Link to comment Share on other sites More sharing options...
Davefjedi Posted May 26 Share Posted May 26 Great looking conversion Definatly look into the MAME route where the FE can display marquee above and instructions below Link to comment Share on other sites More sharing options...
Dedrok Posted May 26 Author Share Posted May 26 23 hours ago, Autosteve said: Yep video jukes are cool and I like Mp3 audio with a good visualization program as long as it has randomize. To much dramas organizing each and every song I want to hear. I'm interested in being able to do this. I think you are taking about displaying the game in 4:3 but using the remainder of the wide screen for game instructions and title header?. 5 hours ago, Davefjedi said: Great looking conversion Definatly look into the MAME route where the FE can display marquee above and instructions below Once I catch up on all my pinball work and fix my virtual pin, I will be looking at expanding into the mame setup i think and sorting out the ratio and marquee. There’s these small monitors but it’s more a cocktail size. This one is to fix another cab that the monitor died in. Link to comment Share on other sites More sharing options...
redferatu Posted May 26 Share Posted May 26 On 25/05/2023 at 7:54 PM, Autosteve said: Yep video jukes are cool and I like Mp3 audio with a good visualization program as long as it has randomize. To much dramas organizing each and every song I want to hear. I'm interested in being able to do this. I think you are taking about displaying the game in 4:3 but using the remainder of the wide screen for game instructions and title header?. https://www.google.com/search?q=mame+vertical+marquee+game+and+instructions+one+screen&client=firefox-b-m&sxsrf=APwXEdfAFWd5efOjEP663GwIDoc9VpLn9A:1685097937334&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjAs93_5pL_AhXLdXAKHX0zC_AQ_AUIBygC&biw=396&bih=747# There is more than one way I think, but this is what you can do 2 Link to comment Share on other sites More sharing options...
Dedrok Posted May 27 Author Share Posted May 27 21 hours ago, redferatu said: https://www.google.com/search?q=mame+vertical+marquee+game+and+instructions+one+screen&client=firefox-b-m&sxsrf=APwXEdfAFWd5efOjEP663GwIDoc9VpLn9A:1685097937334&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjAs93_5pL_AhXLdXAKHX0zC_AQ_AUIBygC&biw=396&bih=747# There is more than one way I think, but this is what you can do Thanks for that. I think I’d just go basic like this one. 1 1 Link to comment Share on other sites More sharing options...
redferatu Posted May 30 Share Posted May 30 Yeah, that's cool. I think you can customise it in whatever way you want. IMO I like the marquee and instructions, but not into the fake cab look. Link to comment Share on other sites More sharing options...
Dedrok Posted May 31 Author Share Posted May 31 Yeah the fake cabs look weird. Link to comment Share on other sites More sharing options...
