Hello... I have recently been given an early NSM Prestige 160 jukebox as the person wanted to have it removed from his home. It hasn't worked in years, but I am hoping to get it working again.
When it is plugged in and started, the lights come on but nothing else happens. I have checked the fuses, found one bad and replaced it. I checked the transformer and found the correct voltage being produced by both windings (43v and 22v). There is no digital display light-up or even recognition of power. One LED diode voltage light does light to indicate the correct voltage to the amps etc. but the other LED diode does not light up. I suppose the problem is, therefore, in the capacitors, transistors, and diodes in that voltage line. Does anyone have an idea of what investigation or direction I should pursue to diagnose and repair my problem?
TheMartian
Thanks!
2 answers to this question
