Page 1 of 11 123 ... LastLast
Results 1 to 10 of 103
Thread: do death saves damage your machine?
    Jul 2009
    narre warren north vic
    1,506
    50 Post(s)
    129 Post(s)
    well as the title suggests do death saves damage your machine? i my self don't think so, nothing more satisfying than the death save if you can pull it off whilst not setting off the tilt. i'm aware that it's an illegal move in any comp , did a great one yesterday on flintstones much to @Jesder 's amazement & its fitted with anti guard rails
    I don't believe it causes any damage but others may have other ideas ?
    May 2013
    NSW
    980
    93 Post(s)
    557 Post(s)
    Not sure if it causes damage but if you have tilt loose enough to do a death save and keep playing its probably a bit too loose.
    Jul 2017
    South Australia
    1,085
    28 Post(s)
    269 Post(s)
    It depends heavily on what kind of floor surface and what kind of fluff people have fitted to their leg levelers.
    Eg.
    Synthetic hard floating floor with standard leg levelers : minimal damage (since stresses are significantly reduced and machine can slide more freely)
    Carpet with rubber feet over levelers : Extreme grip. Attempt a death save and rip the corner out of your new stern.
    Those are merely examples. But it's all about resistance....
    Of course lightweight machines like sterns can be "lifted" at the front fairly easy, but in the carpet example this saves the front corners of cabinet but still stresses heavily on the back legs as the machine lurches sideways on direction and the grippy back legs cant move. Crack.
    Mar 2008
    Melbourne
    559
    12 Post(s)
    95 Post(s)
    No damage, but great fun and satisfying if to pull off without a tilt. Iíve got quite good at it and when I played my second comp, i death saved in front of the td.
    Feb 2008
    goldcoast
    719
    18 Post(s)
    129 Post(s)
    probably wrecks the floor ,not the machine. might be good for the player doing it ,but if your playing next to someone that does it ,it puts you write off.makes me quite angry like people lifting it on to legs in anger after the ball has drained.
    Mar 2014
    Sydney, NSW
    1,397
    60 Post(s)
    478 Post(s)
    It depends on whether the corner join in the cabinet is coming apart. On some machines I've seen, a death save would make the cabinet fall apart!
    www.afpinball.com
    Jul 2017
    South Australia
    1,085
    28 Post(s)
    269 Post(s)
    Quote Originally Posted by ocyen View Post
    I would speculate that the cabinet corner did not start "coming apart" all by itself... it would have needed encouragment. This is a kind of damage (machine abuse) that often happens incrimentally, little bits at a time, until one day it becomes too noticable. Pinball machines will take alot of punishment and not sustain major damage. Deathsaves though are uncalled for and destructive. Even when the floor is less grippy.
    We have peoples private machines in our tourneys. I seen a death save at one of our events recently. Did not incur a tilt wtf? (yes there was "danger", but the treatment of the machine was beyond what we will accept in future) . Tilts will be getting tighter, and deathsaves will not be tolerated anymore, given the abuse peoples machines have occasionally been seen to recieve.
    Sep 2006
    Ballarat, Victoria
    4,014
    25 Post(s)
    734 Post(s)
    on your games, death save as much as you want
    try it on my machines, you wont be invited back
    Aug 2009
    Shepparton Vic
    5,449
    272 Post(s)
    1727 Post(s)
    Quote Originally Posted by razorsedge View Post
    Yes the onus is on the owner setting the tilt where he wants it.
    If you don't want it to happen, set your tilts tight.
    Mar 2008
    Melbourne
    559
    12 Post(s)
    95 Post(s)
    Before I started playing Comps it had become automatic to do it on my machines at home obviously. I obviously had to change that for tournament play because itís a disqualification. Iím not too precious about my home machines and donít give a shit as long as someone doesnít push to Pin through the window
  1. CLIFFY saves TRON
    By devil rider in forum Pinball
    Last Post: 21st March 2012, 06:04 PM
  2. 48 in one and high score saves???
    By ROLLERBALL in forum Arcade Technical and Repair Questions
    Last Post: 22nd July 2007, 09:20 AM
