Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Battery Powered Taito Upright.
  1. #21
    Dec 2016
    Barden Ridge NSW
    3,502
    176 Post(s)
    1273 Post(s)
    Grey doors and chrome bolts....
    Black doors and black bolts....
    I think the black suits much better but the bolts needed the black as well. Not unusual, we had Taito black bolts that went in a lot of Defender cabs straight out of the factory. If your bolts have a black tar like substance to lock the threads, it factory Japanese. If the bolts have red like nail polish on then it was factory Australian.
    All the bolts being blackened after de-chroming with the bench grinder....
    Standard Taito 20" mono cab....
    Now it's a Taito 20" stereo cab. First one ever maybe....
  2. #22
    Dec 2016
    Barden Ridge NSW
    3,502
    176 Post(s)
    1273 Post(s)
    Problem.... monitor controls including ON/ OFF, menu, input select, and volume + and - are all on the face of the monitor and the monitor is under the glass of the machine meaning to adjust or even turn the monitor on would mean taking the glass out. Can't have this and I have no IR remote but I wouldn't have gone down that path anyway. To easy to loose the remote I think. It needs to be hardwired.
    Lucky I have a twin of this monitor so out with the hacksaw and glue I think. Needs to be in a convenient location like on the inside of the coin door....
    Done, 9 wires in total going through the cabinet from the front door and up to the monitor with a connector at the monitor end and the remote panel. This is the connector on the monitor. It has since been set into the monitor case.
    Now I have a question I should have asked earlier. On a multi game board when the game is horizontal or east / west, the monitor will be in it's normal position as in the monitor will have it's on off switch etc at the bottom of the screen but when the screen is rotated to vertical or north / south configuration, do the games require the monitor to rotate clockwise or anti-clockwise. This is important because I have to allow for the monitor wires to not bind and if I get this wrong, the games will be upside down in north / south games. ATM I have the screen rotating anti-clockwise from east / west to north / south so I have a 50-50 chance I have it right already.
    Waiting on an answer to this before I can proceed.
  3. #23
    Nov 2006
    bunbury WA
    24,314
    46 Post(s)
    1198 Post(s)
    Saint Kitts Nevis Anguilla
    Quote Originally Posted by Autosteve View Post
    https://i.imgur.com/axoyYwql.jpg
    https://i.imgur.com/4rLw5A0l.jpg
    https://i.imgur.com/YY1vYa4l.jpg
    If going vertical with a 60in1 it has a dip switch to flip?
    you can always expect change in life..except from vending machines
  4. #24
    Dec 2016
    Barden Ridge NSW
    3,502
    176 Post(s)
    1273 Post(s)
    Quote Originally Posted by narf_ View Post
    Maybe, I'm not sure. That could flip all the games no matter north south or east west?. It could also be for flipping table games between first and second player?. I really don't know.
  1. Taito Space Invaders L shaped Taito upright
    By tevo in forum Arcade Technical and Repair Questions
    Last Post: 19th February 2019, 04:17 PM
  2. Battery powered to power supply?
    By Dannymh in forum General Chat
    Last Post: 29th June 2011, 01:31 PM
  3. Taito upright SI
    By peely in forum Arcade
    Last Post: 27th June 2010, 03:56 PM
