- 0
Classic Stern multiple switches firing at once
Recently Browsing 0 members
robm
Have an issue with Stern Quicksilver, if i drop the middle right drop target, it accumulates points continuously until the 3 bank of targets resets.
Put the machine in switch test, and when i hit the middle right drop target switch (31), switch 23 also appears on the displays (which is one of the drops on the left bank of targets). They both share a brown yellow wire. I tested the diodes (in circuit on both sw 31 and sw 23, and both test good - and the same as the other diodes nearby. When i test sw 23 by itself in switch test, it only fires itself.
I also noticed that standup target sw 15 in swtich test also fires sw 7 (tilt) - but it doesn't tilt during a game. Interestingly, sw 15 also has a brown/yellow wire.
Any suggestions on where to from here - should i replace the diode on 31 even though it tests OK?
19 answers to this question
