gt-ray Posted April 29, 2019 Share Posted April 29, 2019 Hi I have this fault ever time I turn on the machine I thought it was a battery from the mother board in the computer.. Still nothing.. unless it was a dud battery Any ideas. Link to comment Share on other sites More sharing options...
0 redferatu Posted April 29, 2019 Share Posted April 29, 2019 It's not finding anything to boot from yeah? If it were a regular PC is add a ps2 keyboard Sent from my HTC 2PZF1 using Tapatalk Link to comment Share on other sites More sharing options...
0 Slypinball Posted April 29, 2019 Share Posted April 29, 2019 Just did a safari you now need to set all your bios back to what it was not sure if it is the same safari but ill try and find the link. What pc is in it? Sent from my SM-G973F using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 Slypinball Posted April 29, 2019 Share Posted April 29, 2019 Does it have a Dell optiplex 740 in it? Sent from my SM-G973F using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 torchwolf Posted April 29, 2019 Share Posted April 29, 2019 You'll need to connect a keyboard and press whatever key it uses (usually F2) to get to the bios settings. You're going to have to disable some of the drive boot options and ensure that you have the main hard drive being the primary drive to boot from in the boot order. You're also going to want to change the setting that says stop on keyboard failure, this will make sure the pc boots regardless of whether there is a keyboard attached. Also check the option for what the PC does on AC Recovery (Power recovery), make sure this says that it will power on on AC Recovery. This will make sure that the PC will boot when the Arcade Cabinet is powered on. Make sure you save these settings before you exit. Link to comment Share on other sites More sharing options...
0 BoardMan Posted April 30, 2019 Share Posted April 30, 2019 I was just involved in setting the bois settings on one of these. I'd say the battery is flat and you need to set all the bios settings. Link to comment Share on other sites More sharing options...
0 gt-ray Posted April 30, 2019 Author Share Posted April 30, 2019 - - - Updated - - - Thanks for all the reply.. I'll check it out and do those setting to see if it works. Link to comment Share on other sites More sharing options...
0 Slypinball Posted April 30, 2019 Share Posted April 30, 2019 This is what mine is set to Optiplex740 -System +Boot Sequence 1. CD/DVD/CD-RW Drive 2. USB-ZIP 3. USB-Device 4. Hard Drive 5. USB-FDD 6. USB-CDROM 7. Non-Integrated NIC 8. Diskette Drive + HDD Boot Sequence [don't care] -Drives +Diskette Drive: USB +Drive 0: SATA-0: ON +Drive 1: SATA-1: ON +SMART Reporting: OFF -Onboard Devices +Integrated NIC : ON +Integrated Audio : ON +USB Controller : ON +Rear Triple USB : ON +Real Dual USB : ON +Front USB : ON +LPT Port Mode : EPP +LPT Port Address : 378h +Serial Port #1 : COM1 -Video +Primary Video : Onboard/Card +Video Memory Size : 16MB -Performance +HDD Acoustic Mode : Bypass -Security +Admin Password: None +System Password : None +Drive 0 Password : None +Drive 1 Password : None +Password Changes : Unlocked +Chassis Intrusion : OFF +TPM Security: OFF +No Execute: OFF -Power Management +AC Recovery: ON +Auto Power On: OFF +Low Power Mode: OFF +Remote Wake Up: OFF +Cool and Quiet: OFF +Suspend mode: S3 -Maintenance +ASF Mode: OFF -POST Behavior +Numlock Key: On +Fast Boot: On +Post Hotkeys : Setup & Boot Menu +Keyboard Errors: Do Not Report Sent from my SM-G973F using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 gt-ray Posted May 10, 2019 Author Share Posted May 10, 2019 @Slypinball I tried this I don't how to change the order. Do i press space or enter If I throw my keyboard at it will that work. Link to comment Share on other sites More sharing options...
0 Slypinball Posted May 10, 2019 Share Posted May 10, 2019 Up and down arrows used to select Letter U and D should move the order I think spacebar made the number show or not Sent from my SM-G973F using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 gt-ray Posted May 10, 2019 Author Share Posted May 10, 2019 Thanks that what I thought didn't work.. I'll try again. Link to comment Share on other sites More sharing options...
0 Slypinball Posted May 10, 2019 Share Posted May 10, 2019 I do remeber it took me a bit to work it out aswell just cant remeber what combination got it to work. I dont have the pc here with me to have a look Sent from my SM-G973F using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 gt-ray Posted May 11, 2019 Author Share Posted May 11, 2019 Press up and down key to select it.. Then press U and D key to move the position.. That's how you do it if anyone wants to know.. all good and working now... Thanks for everyone's help.. Link to comment Share on other sites More sharing options...
gt-ray
Hi
Any ideas.
12 answers to this question
