Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
Thread: Elvira & The Party Monsters
  1. #21
    May 2016
    1,733
    119 Post(s)
    573 Post(s)
    Quote Originally Posted by Boof Head View Post
    To lift the door and stop it rubbing you’ll need to remove it from the frame. Tap the hinge down with a block of wood as the hinge will have stretched.
    Yep, try this for sure. What's rubbing? The coin door itself on the frame or the coin door frame when it was interred into the cab? Sometimes the door itself may require some manipulation and bending back of the inside lip with pliers or similar. I've had to do this a number of times.
    Quote Originally Posted by Coon82 View Post
    Great transformation Glenn @Glenn70. It's always nice to see and hear about your projects.
    Congrats Mike @mix_vt_cal. I'm sure you're very happy with how it's come along and seeing some momentum is always a great motivator.
    Thanks heaps Joe. I enjoyed this one.
  2. #22
    May 2011
    Melbourne
    901
    54 Post(s)
    264 Post(s)
    Thumbs up
    Tonight’s tasks.... Boards in and shiny bits on.
    So shiny Jeff @Railways
    Time for one of these!
  3. #23
    May 2011
    Melbourne
    901
    54 Post(s)
    264 Post(s)
    Earlier in the week cleaned up the glass and translight.
    Translight was pretty dirty.
    Also has some damage in a corner.
    Cleaned up a bit.
    Back behind glass. You know - far from good, but looks good from afar.....
  4. #24
    Jan 2007
    695
    23 Post(s)
    154 Post(s)
    Warm water a soft cloth and some velvet soap will removal all the brown stain on the back of the translite. Give it a try, I've done it on countless translites and they always come up looking white and clean. Wet the cloth in warm water, squeeze it out gently and wipe the surface of the translite to remove any loose dirt and make the surface damp. Rinse the cloth in the water again, squeeze enough water out so that when you run the soap over the surface it makes a light lather on the cloth. Gently run the soap cloth across the surface of the translite and the grime will disappear.
  5. #25
    Jul 2009
    SA
    2,987
    93 Post(s)
    856 Post(s)
    Quote Originally Posted by mix_vt_cal View Post
    https://www.aussiearcade.com/attachm...6&d=1558197488
    https://www.aussiearcade.com/attachm...7&d=1558197488
    Cleaned up a bit.
    https://www.aussiearcade.com/attachm...8&d=1558197488
    https://www.aussiearcade.com/attachm...0&d=1558197488
    https://www.aussiearcade.com/attachm...9&d=1558197488
    This is what you want:
    https://www.ministryofpinball.com/en...backglass.html
  6. #26
    May 2011
    Melbourne
    901
    54 Post(s)
    264 Post(s)
    Quote Originally Posted by Pinballer View Post
    I tried just about every other product I have. I stared with Dishwashing liquid and moved up from there. Nothing really worked too well, and I wasn’t prepared to scrub with harsher chemicals.
    I’ll give your suggestion a go and report back.
    Quote Originally Posted by Boots View Post
    I have considered the CPR backglasses. They even do a mirrored one which is cool.
    Trouble is the colours are way off. Especially the skin tones.
    I would need to see one in person before I decided to pull the trigger.
  7. #27
    Aug 2010
    SA
    799
    65 Post(s)
    285 Post(s)
    Yep Spot on ! I bought a mirrored one 24 mths ago for a EATPM restore and ended up cleaning and using original BG as the CPR colours were not great.
  8. #28
    May 2016
    1,733
    119 Post(s)
    573 Post(s)
    Really coming along Mike and starting to look beautiful. Now, I believe the PF is the only thing to install? Just remember me when it's turned on for the first time and tweaked. I will then attend for a game or two. Really coming along nicely.
  9. #29
    Sep 2007
    NSW
    101
    8 Post(s)
    38 Post(s)
    Quote Originally Posted by Smithy View Post
    You guys must have good eyes, i put that backglass up against the old trans and the BG ( to me ) looked a million times better. maybe @gtray can post some comparisons ?
    "Lost in the Zone"
  10. #30
    May 2011
    Melbourne
    901
    54 Post(s)
    264 Post(s)
    A bit more work completed.
    Light board, displays and globe holders cleaned and put back in.
    All boards have been wired back in now, except for the playfield looms obviously.
    Couple of soldering jobs required and now done.
    Looking like a Pinball machine again!
    @markc had an interesting Facebook post a few weeks back, showing a couple of items he'd dug out of the unopened parts boxes.
    Well, as they say timing is everything!
    Probably didn't need these, but NOS Elvira Jumper Bumpers have to be better than rebuilt old ones, right?
    I've added these to my list of expenses for this pin, and it is getting scary!
    I think I'll clean up all the plastic posts and see how they turn out. I was going to replace them all, but......
    I've also been working on the ball guides. Have polished with Autosol, and have tried re-graining with a scotchbrite pad.
    I think I'm going to need to move up from hand polishing and try a wheel in a a drill or similar.
    I can't seem to get the guides looking even by hand.
    That's it for now.
    PS - Sorry about the pics. Some have come via my phone and some via the PC.
