Jamie Posted December 7, 2018 Share Posted December 7, 2018 Hoping to set up my new 60 in 1 arcade classic from RTBB into my namco classic collection. Aside from connecting the jamma harness is there anything else i need to do? Its using a crt screen. Thanks. Sent from my SM-G925I using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
0 prktkljokr Posted December 7, 2018 Share Posted December 7, 2018 60 in 1 are pretty straight forward, depending on your cab set up you can configure it for a cocktail, stand up 1 player to stand up two player. Most 60 in 1 boards come with a small book, if not here is a rough guide. What the dip switches do: Dip 1, flips screen, so if you fire it up and the game is upside down on your screen, you correct it with this dip. Dip 2, Display mode, if using the arcade monitor leave it in the off position, flick it on for VGA hook up. Dip 3, High score saver, just flip it on, does not hold the high score on some games and resets after the machine is turned off (from memory) Dip 4, if you flick this one you can change the settings of the board, you do have to turn the machine off, flick this dip and switch the machine on for this to work, press the service switch to toggle through the pages, press player 1 after each change to save to memory. Hope thats what you were after :D Link to comment Share on other sites More sharing options...
0 Boots Posted December 7, 2018 Share Posted December 7, 2018 First thing is check the voltages are correct at the harness before plugging in the board No more than 5.25v Once all connected flick dip 4 to on and turn on the machine and using button 2 (either player controls) move through the setting pages Button 1 to modify a setting P1 or P2 start saves your settings On the free play and cabinet type page you use the up and down to navigate but you will also need to use the left and right when setting the cabinet type. To get a 2 joystick upright cabinet move down to cabinet type and if it's already on 1 joystick move to the right and press button 1 this will change it to 2 control cabinet These are reasonably easy to use but the manual is poorly translated from Chinese Link to comment Share on other sites More sharing options...
0 Jamie Posted December 8, 2018 Author Share Posted December 8, 2018 All went well thanks. Love the difference the old crt screen and dodgy speaker make on these old games. Strangely though quite a few switches seem to be packing it in now. Might have to buy a new set. Any recommendations?? Sent from my SM-G925I using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
Jamie
3 answers to this question
