gardog62 Posted November 25, 2018 Share Posted November 25, 2018 Hi Guys have a Gottlieb Stargate and the dmd is just showing garbage .Tried give cables aa bit of a wiggle in case it was a dodgy connection but still garbage .Not sure where to start .Any ideas ? Thanks in advance Link to comment Share on other sites More sharing options...
0 ocyen Posted November 25, 2018 Share Posted November 25, 2018 You posted this thread twice - might want to delete one so all the replies are kept in the one spot :) Can you take a photo of the display? Seeing the garbage helps diagnose what might be causing it. What are the voltages at the display? Did you unplug the DMD while the game was on? Link to comment Share on other sites More sharing options...
0 gardog62 Posted November 25, 2018 Author Share Posted November 25, 2018 Sounds pretty dumb but i am not sure how to delete duplicate post . Will try to take a photo tomorrow and check voltages I dont believe i unplugged while on .if i did it would have been after this fault emerged . I know i was trying to jiggle connections to remedy issue . Thanks will update tomorrow Link to comment Share on other sites More sharing options...
0 toads Posted November 25, 2018 Share Posted November 25, 2018 Sounds pretty dumb but i am not sure how to delete duplicate post . Will try to take a photo tomorrow and check voltages I dont believe i unplugged while on .if i did it would have been after this fault emerged . I know i was trying to jiggle connections to remedy issue . Thanks will update tomorrow other thread deleted:) Link to comment Share on other sites More sharing options...
0 gardog62 Posted November 25, 2018 Author Share Posted November 25, 2018 Cured .Thanks Ocyen . Checked voltages and manual .Was missing 5v dc Was a fuse i tested in game .looked good not even discoloured . Google led me to another inferior forum and made me believe it was a way more complex issue than i was capable of curing . I assumed it had to be one of these complex faults as display matched their symptoms . Once pointed in the right direction and turned out to be a simple fix . Link to comment Share on other sites More sharing options...
0 ocyen Posted November 26, 2018 Share Posted November 26, 2018 Good job. Always test fuses out of circuit :) Link to comment Share on other sites More sharing options...
gardog62
Thanks
in advance
5 answers to this question
