WW help with identifying correct replacement part
Hi all
I'm hoping someone can help me identifying the correct replacement part for my WW.
Its the playfield slide lock on the left hand side which is bent, making raising the playfield difficult as it doesn't operate as intended.
There seems to be two different types available at the usual Australian parts suppliers:
A-17749.1-1
04-12723.1
The pictures look the same so I'm not sure which one is correct. It's the "slide mechanism" shown on page 1-4 in the operations manual.
Any help is appreciated!
@iroczvinnie I'd search for both part numbers here: https://www.ipdb.org/files/2768/Williams_1993_White_Water_Parts_List.txt
You may find they are both numbers from the same assembly.
Edit, actually neither appear. A-16637-1 playfield slide left and A-16637-2 is right side. Is that the (possibly superceded) part number?
E.g.
https://www.marcospecialties.com/pinball-parts/A-16637-1
https://www.marcospecialties.com/pinball-parts/A-16637-2
ok, there's a replacement part number which is one of the ones I listed. Big price difference between AU suppliers, however only 1 of them has the spring as well, so will go with that supplier. Thanks again @ajfclark for the tip to check parts listing. noobie fail.... lol
Not a fail at all. Not all machines have part listings on ipdb, and as you can see, sometimes those numebrs don't actually map to what's available.
