Likes Likes:  0
Results 1 to 5 of 5
Thread: Black rose - coil and switch column problem ?
    Mar 2016
    New South Wales
    364
    8 Post(s)
    82 Post(s)
    Hi guys
    I have a mystery problem with my Black Rose.
    1. When I turn on the game, I get no error message
    2. When I start a game the flippers do not work and the 'davy jones locker' coil starts firing (about 10 seconds between firing)
    3. When I go into test mode (solenoids) all coils work fine
    4. When I go into test mode (switches) none of column 2 switches register
    Things I have done
    1. Tested all switches in column 2 for continuity to back of CPU board (no issues)
    2. Replaced all diodes on column 2 switches
    3. Swapped out the U20 chip
    4. Swapped the whole CPU board into another game (no issues)
    5. Sent the power driver board away for checking (no issues)
    Now I don't know what else to do or check
    Any advice or suggestions would be greatly appreciated
    Dec 2016
    Barden Ridge NSW
    3,419
    175 Post(s)
    1250 Post(s)
    Take the wire off the coil that keeps kicking, put in switch test and from under the playfield with your fingers work every switch especially the ones in the next column to the right of the effected one. Note each switch is working and not 2 switches or the wrong switch coming on.
    The machine will not register a faulty switch till it has failed for 50 balls.
    Look at the harness around where the playfield prop holds the playfield up. It runs extremely close on Black Rose through memory.
    Mar 2016
    New South Wales
    364
    8 Post(s)
    82 Post(s)
    Update
    Still all the same issues:
    flippers not working
    column 2 switches not working
    one coil firing randomly (when a game is started)
    however when I turn machine on it comes up with error - check left flipper switch, check right flipper switch, check right upper flipper switch
    Any suggestions would be appreciated
    Mar 2010
    Wimmera, Victoria
    6,876
    117 Post(s)
    1933 Post(s)
    With the machine OFF, check & reseat all PCB plugs.
    My pins: Wild life EM, Top Score Em, Space Mission EM, Target Alpha EM, Cleopatra SS, Pin*Bot SS, Indiana Jones WPC, Black~Rose WPC.
    My Arcades: Funland Rifle EM, Hankin Table 20", Mame 20" Horizontal Cab, 17 in 1 Horizontal 20" cab, Outrun2 sit down game rear projection, Foosball table.
    Mar 2016
    New South Wales
    364
    8 Post(s)
    82 Post(s)
    Update. I think I've solved the puzzle. The ramp coil issue was related to a flaky switch. The column of switches not working could be due to a GI light that had shorted to earth. I've sent the cpu board off to be repaired
  1. TZ clock optos all out How to jumper 9th column of switch matrix?
    By robm in forum Pinball Technical and Repair Questions
    Last Post: 21st December 2017, 06:07 PM
  2. Black Rose Switch Matrix issue
    By skids in forum Pinball Technical and Repair Questions
    Last Post: 25th June 2015, 02:57 PM
