jeffez Posted October 29, 2018 Share Posted October 29, 2018 Hi guys, I'm after at least the top part of a dreamcast shell. Not terribly fussed on condition and yellowing, as long as there's no major damage. Cheers Link to comment Share on other sites More sharing options...
mckie1 Posted October 29, 2018 Share Posted October 29, 2018 We have one on a shelf you can have. Please shoot through postage details and I will try and disassemble soon [emoji23] We only have it for the joystick ports for an arcade project - don’t judge [emoji23] Cheers, Dave Link to comment Share on other sites More sharing options...
jeffez Posted October 29, 2018 Author Share Posted October 29, 2018 We have one on a shelf you can have. Please shoot through postage details and I will try and disassemble soon [emoji23] We only have it for the joystick ports for an arcade project - don’t judge [emoji23] Cheers, Dave Awesome man. Sounds great. Let me know how much. I'm hardly one to judge, the nerdier the better. I'm resurrecting an abandoned case mod project. Will PM shortly :) Link to comment Share on other sites More sharing options...
razor Posted October 30, 2018 Share Posted October 30, 2018 We have one on a shelf you can have. Please shoot through postage details and I will try and disassemble soon [emoji23] We only have it for the joystick ports for an arcade project - don’t judge [emoji23] Cheers, Dave Dave, Is the power supply available? Cheers Ray Sent from my iPhone using Aussie Arcade Link to comment Share on other sites More sharing options...
mckie1 Posted October 31, 2018 Share Posted October 31, 2018 [emoji106] Please send through address ;) Link to comment Share on other sites More sharing options...
mckie1 Posted November 2, 2018 Share Posted November 2, 2018 Have found DC and taken out psu and removed front ports. Also found a spare vga box. Will send next week. Link to comment Share on other sites More sharing options...
jeffez Posted November 6, 2018 Author Share Posted November 6, 2018 Have found DC and taken out psu and removed front ports. Also found a spare vga box. Will send next week. Legend, cheers man Link to comment Share on other sites More sharing options...
jeffez Posted November 12, 2018 Author Share Posted November 12, 2018 Dave, Is the power supply available? Cheers Ray Sent from my iPhone using Aussie Arcade Just a heads up incase you haven't got it yet. This is a japanese unit so it may not be a 220V board unless it was already swapped at some point. Link to comment Share on other sites More sharing options...
mckie1 Posted November 13, 2018 Share Posted November 13, 2018 Correct :) I put a note on the psu showing 100 volt just in case ;) Link to comment Share on other sites More sharing options...
Frank_fjs Posted November 13, 2018 Share Posted November 13, 2018 You can convert a Japanese PSU to 240V with a simple swap of a couple of resistors and capacitors. Link to comment Share on other sites More sharing options...
MangledLeg Posted November 14, 2018 Share Posted November 14, 2018 You can convert a Japanese PSU to 240V with a simple swap of a couple of resistors and capacitors. Link please Frank - that sounds radtastic!!!! Link to comment Share on other sites More sharing options...
Frank_fjs Posted November 14, 2018 Share Posted November 14, 2018 Paging @xodaraP to fill you in on the details, he's done a few now. Link to comment Share on other sites More sharing options...
xodaraP Posted November 14, 2018 Share Posted November 14, 2018 I'll post the link up when I get home and I can find it, depending which board revision you have its 2 resistors and a cap, or on the later revision just a cap. If you're running a GDEMU or USB-GDROM it is also recommended to disable the +12 as well (it's only required by the GD-ROM drive) Did I see somewhere that someone has a spare VGA box? Link to comment Share on other sites More sharing options...
newy16216 Posted November 14, 2018 Share Posted November 14, 2018 Thanks for the info just received a USB gdrom in the mail today will look into disabling the 12v thing Link to comment Share on other sites More sharing options...
Frank_fjs Posted November 14, 2018 Share Posted November 14, 2018 Here's the link for the power mod: https://dragoncity17.wordpress.com/2016/10/25/dreamcast-convertir-une-alim-110v-en-220v/ Link to comment Share on other sites More sharing options...
xodaraP Posted November 14, 2018 Share Posted November 14, 2018 Dreamcast shell I'm happy to do this for you if you need as well. Make sure you order the correct sized caps too (I originally ordered Rubycon and they were too tall) - the correct cap to replace it with is a Nichicon (which is also the brand removed) For the 2 62k caps, one is a 1/4w through hole, the other is a 0805 metric SMD or you can use another one of the 1/4w through hole and just solder the resistor flat with the pins soldered to the SMD pads. Link to comment Share on other sites More sharing options...
mckie1 Posted November 14, 2018 Share Posted November 14, 2018 I'll post the link up when I get home and I can find it, depending which board revision you have its 2 resistors and a cap, or on the later revision just a cap. If you're running a GDEMU or USB-GDROM it is also recommended to disable the +12 as well (it's only required by the GD-ROM drive) Did I see somewhere that someone has a spare VGA box? We did have one but gave it away with the shell. We probably have another somewhere but might take some time to find in the pile of unused a/v gear :( Link to comment Share on other sites More sharing options...
xodaraP Posted November 14, 2018 Share Posted November 14, 2018 Dreamcast shell If the guy who got the VGA box doesn't want it, I'd be keen on it :P If you come across another one, let me know :) Link to comment Share on other sites More sharing options...
MangledLeg Posted November 14, 2018 Share Posted November 14, 2018 Thanks for the technical discussion guys - will have a read and add it to my to-do list!! Sent from my iPhone using Aussie Arcade Link to comment Share on other sites More sharing options...
Autosteve Posted November 14, 2018 Share Posted November 14, 2018 Don't be shy boys. I have a many Jap Dreamcasts. Is 3 for $100 to much?. You would be getting them as is but out of the 3, 1 will definitely be working and you may be lucky and get 3 workers. I also have arcade interface boards, "Coin for time boards" that have arcade button/ joystick interfaces on them as well to suit Dreamcast Xbox etc. I'll do them for $50 a piece. PM if your interested. Link to comment Share on other sites More sharing options...
xodaraP Posted November 14, 2018 Share Posted November 14, 2018 Thanks for the technical discussion guys - will have a read and add it to my to-do list!! Sent from my iPhone using Aussie Arcade No problem. Let me know if you run into any issues, I've done 5 of these now and all are working well :) Link to comment Share on other sites More sharing options...
jeffez Posted November 15, 2018 Author Share Posted November 15, 2018 Awesome I wasn't aware they could be converted to 240 that easily/cheap. Is disabling the 12V with GDEMU still recommended for a stock 240 supply? What are the risks if it isn't? Link to comment Share on other sites More sharing options...
xodaraP Posted November 15, 2018 Share Posted November 15, 2018 Dreamcast shell Only if you're running a GDEMU or USB-GDROM The risk is the voltage regulator will overheat and die eventually and you'll get an electrical smell, some people don't notice anything, others do Link to comment Share on other sites More sharing options...
Frank_fjs Posted November 20, 2018 Share Posted November 20, 2018 Don't be shy boys. I have a many Jap Dreamcasts. Is 3 for $100 to much?. You would be getting them as is but out of the 3, 1 will definitely be working and you may be lucky and get 3 workers. I also have arcade interface boards, "Coin for time boards" that have arcade button/ joystick interfaces on them as well to suit Dreamcast Xbox etc. I'll do them for $50 a piece. PM if your interested. @felixthadog Link to comment Share on other sites More sharing options...
