Results 1 to 8 of 8
Thread: MDF thickness for cabinet
    Jan 2018
    Queensland
    6
    Hi All,
    What is the best/preferred thickness of MDF for building a jukebox cabinet? 32mm or 25 mm, I'm putting it on castors so weight is not an issue
    Chewers
    Randy
    Jun 2011
    Morwell, Victoria
    2,726
    43 Post(s)
    924 Post(s)
    Id go the 25 mm unless you really want a super heavy duty cabinet for some reason
    Putting out the feelers for my next early Gotlieb project
    Apr 2012
    我不想乱跑,但我确实想戒&#25
    3,072
    96 Post(s)
    997 Post(s)
    Man both those would likely Be over kill, 18mm would do it, likely get away with even 16mm
    25-32mm is bloody thick. You would need to upgrade your homes foundations to support the weight
    Jul 2009
    SA
    2,843
    90 Post(s)
    815 Post(s)
    I would recommend 18mm
    More common size in commmercial so you can get a large cover sheet for around $10
    Also suits t-mould better
    Dec 2010
    N/A
    521
    14 Post(s)
    55 Post(s)
    I built a roll top werlitzer type and the chassis is 18mm and a fair weight and rock solid. I had to sell my cnc so never finished the edges front and back and now want to get rid of it, need the room, send me a pm if you want a 90% complete project with or without the sound system
    If I can't sell it, it is going to be chopped up sadly
    Feb 2009
    360
    50 Post(s)
    163 Post(s)
    That's some nice craftsmenship right there , too good to be chopped up , but Spotify on a Bluetooth setup is a bit smaller as I have learned , done the touchscreen jukebox thing , kids n their phones don't appreciate
    Jan 2018
    Queensland
    6
    That my friend is way too much time and craftsmanship to chop up. How much are you wanting for it and where are you based my friend?
    Dec 2010
    N/A
    521
    14 Post(s)
    55 Post(s)
    sorry not meaning to take over your thread but maybe my project can be someone else's less alot of work & effort and would rather save it than go to the bin. I have kids now and lost my cnc and lack time and space
    there is alot of work in it but would like $1000 to $1250 for the whole cabinet, lighting, wiring would stay in it, over 100 hours in designing, all the inner mdf chassis is cleared and outer is all 3 coats of danish oil (does not include amp or speaker system) but open for offers for the lot as well.
    the whole front panel is huon pine and purple heart (which is solid 18mm machined down from slabs and edge biscuit joined)
    the side panels, sub panel with over 900 holes, logo panel which is a pull out hidden drawer with light when pulled out and speaker panels are all jarah (all 18mm machined down from slabs)
    all the lights can be turned on or off
    2 individual volume controls at the back
    basically daughter is turning into a little artist and she needs a art table so need the room and cover the cost of a semi professional art table
    am in the Newcastle area
    these are of early days showing the chassis (everything keys in together and glued - no butt joints and then varnish to protect it) and after it's initial danish oil, but the timber has darkened over time
  1. Rubber thickness
    By felixthadog in forum Pinball
    Last Post: 20th November 2015, 07:12 PM
  2. glass thickness
    By benji1861981 in forum Arcade
    Last Post: 10th February 2011, 12:42 PM
  3. MDF Thickness for cab
    By Big Giant Head in forum Mame Cab Hardware and Software Discussion
    Last Post: 4th June 2010, 10:35 PM
  4. Cab ply thickness?
    By tnpshow in forum Pinball
    Last Post: 13th September 2009, 07:35 PM
  5. CP thickness??
    By Ric in forum Video Arcade Restorations and Projects
    Last Post: 15th March 2007, 05:41 PM
