Likes Likes:  0
Results 1 to 7 of 7
Thread: Xbox original requires repair/TLC
    Jun 2012
    QLD
    241
    9 Post(s)
    44 Post(s)
    Is there anyone within the forums or external who fixes original Xbox's?
    Background; My console wont read discs anymore unfortunately. It is a bone stock console that was repaired about 6 years ago for the same problem.
    Any help appreciated!
    Wanted - Neo Geo AES games (PM me Please)
    Wanted - CPS2 game boards (PM me Please)
    Jun 2018
    f**kery
    72
    14 Post(s)
    Watching as my Xbox keeps shutting off
    interested to know if their are repairmen around for these units
    Dec 2016
    Barden Ridge NSW
    3,894
    195 Post(s)
    1396 Post(s)
    Quote Originally Posted by xb74 View Post
    Dirt and dust on the laser. Compressed air in the DVdrive maybe or else pull machine apart, remove DVDrive, pull screws out, remove lid of DVDrive and manually clean the crap off the laser.
    Quote Originally Posted by 1973 View Post
    Yours is somewhat harder but still relatively easy to fix.
    Absolutely nothing you have done but the finger acids on the Chinese assemblers fingers that assembled your machine originally. This video shows you "exactly" how to repair it.
    Jan 2016
    New South Wales
    1,202
    41 Post(s)
    380 Post(s)
    I would mod it. Bypass the optical, save your discs, play backups. Perfectly legal and reasonable way. The mod nowadays is a bios mod, so no modchip. I'm about to do two of them for myself, but haven't done it yet so I'm just talking from my reading.
    Sent from my HTC 2PZF1 using Aussie Arcade mobile app
    Jun 2018
    f**kery
    72
    14 Post(s)
    What video?
    nothing is showing sorry
    Dec 2016
    Barden Ridge NSW
    3,894
    195 Post(s)
    1396 Post(s)
    What video?
    Sorry, my bad....This video. It is referring to trace corrosion.
    The problem occurred when the board was handled, flipped over actually on the assembly line prior to the board lacquer being applied. Acid from the worker's fingers got onto the raw copper traces, ( very common to be able to see fingerprints under the lacquer), and this acid over time eats away the traces/ traces. You can often see the damaged traces by eye in that one part of the board the video points to.
    To repair, you bridge out the damaged section of trace or traces by following the trace back to the nearest solder point. solder to that solder joint and do the same the other way so your link forms a bridge over the damaged section of trace.
    Once done your machine should be fine. If you find no corrosion on these group of traces start looking around the supa capacitor. Get back to me if you need help with that type of repair.
    Jun 2018
    f**kery
    72
    14 Post(s)
    Quote Originally Posted by Autosteve View Post
    https://youtu.be/SQxbSMo3I0Q?t=29
    Sorry for not replying sooner
    the above sounds like what is needed but well above my skills
    I'll see about taking it to someone to look at perhaps but thanks again for the reply
  1. Will xbox a 360 joystick control work on a original xbox running COOPS 4?
    By Homereatchiili in forum Console and Handheld
    Last Post: 16th February 2013, 10:19 AM
  2. XBOX original needs repair
    By xb74 in forum Console Modding and Repair Help
    Last Post: 27th June 2012, 06:14 AM
  3. Original Xbox repair
    By neo-mvs-man in forum Console Modding and Repair Help
    Last Post: 30th March 2012, 08:19 PM
  4. Xbox softmod requires dash update, HELP?
    By inthemix in forum Console and Handheld
    Last Post: 9th May 2009, 06:34 AM
