Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Dreamcast Dedicated JAMMA mod (AV help needed)
  1. #21
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    Quote Originally Posted by cps2luva View Post
    just wanted to say thanks for sharing your progress here, feel like it is a useful resource for anyone who will attempt this in the future
    nice work, cant wait to see the completed result!
    Thanks! it's been great fun.
    I do however feel a little guilty of post spam though. Unfortunately, since I'm on mobile I can't edit my posts.
    I will return later once I have access to a pc and edit and consolidate all progress into a single post. Goimg to be a fair amount of clean-up but should be easier to read as a single post instead of scrolling through the thread.
    Limitations of mobile.
    Sorry for the constant thread bumping.
    Sent from my SM-G925I using Aussie Arcade mobile app
  2. #22
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    May have hit a brief snag.
    Still waiting on the rgb booster. However, I have sent direct rgb/sync to the jamma edge and trialed it through my Astro City. I do get a signal though it is black and white scattered garbage.
    I have put up a brief video (not of the displayed screen) and had a comment in regards to needing to force 60hz refresh.
    I figured direct rgb would just be dull and require a rgb booster to fix the brightness but needing to run at 60hz may affect the sync, correct? Trying to work out how to go about hard forcing 60hz output on a PAL unit that already lacks video out.
    Shameless self plug of current progress
  3. #23
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    So I guess even on PC I can't remove my double posts and compress the thread :/ bummer.
    Anyway, I've connected the Dreamcast to my CGA to VGA converter.
    I was worried about my green line being busted. turns out it's fine.
    I'm getting brief video out and not holding sync.
    Progress is progress though. Getting at least a brief view of some form of a signal through RGB is a GREAT sign of life and a step in the right direction. Hopefully the RGB amp will help to stabilize the sync but I'm still wondering if it's because the PAL unit is outputting at 50hz native.
    I have purchased a cheap US NTSC unit from eBay that had dead controller ports. This is a non-issue as It's probably just a blown fuse. Once all the hard work is done in prototyping on this console, I can do a case swap, Mod the US NTSC unit in the same way, and hopefully by the time I'm done, I will have a single unit capable of running off JAMMA AND a TV. (“¿Porque No Los Dos?”)
    Very low quality, vertical video. But Progress is progress no matter now small.
  4. #24
    Mar 2010
    Adelaide
    6,693
    44 Post(s)
    536 Post(s)
    I doubt it will help but it's worth a shot, have you tried pressing the AUTO button on the VGA encoder? Experimented with its various settings, resolutions?
    SEGA love: click | Nintendo love: click
    PC Engine love: click | Latest retro finds: click
  5. #25
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    Yeah, just tried flipping through resolutions. It seems to not like displaying moving video. Displays the static logo fine, when flipping through resolutions on the menu screen and during boot animation it's garbled trash. Something must be going on with sync.20190316_193623.jpeg
  6. #26
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    Booster is a no go. RGB and 5v GRND all connected, no longer outputs a video signal with amp installed.
  7. #27
    Feb 2015
    NSW
    89
    1 Post(s)
    16 Post(s)
    Taken a short break and just gathering parts and researching more for now. In the meantime, my MGCD arrived today and trying to suss it out. Boots with sound. I guess I need to figure out dip settings and make an extension harness and re-route a few wires to the right pins. I know it's JAMMA in the sense that MVS is 'JAMMA' (It is but isn't).
    Anyone with a MGCD got a dip settings guide?
    I did hear that the MGCD prefers a JP console but this seems to not be the case. I can only get a response out of my PAL unit. 20190328_170140.jpeg20190328_170146.jpeg
  1. DreamCast to Jamma
    By Savage in forum Arcade
    Last Post: 16th September 2008, 07:54 PM
  2. Dreamcast boot cd needed
    By wrxrick in forum Console and Handheld
    Last Post: 17th November 2007, 10:51 PM
