brentos82 Posted September 29, 2018 Share Posted September 29, 2018 Hello everyone The inside of the sides of my cabinet are peeling. It's some type of black laminate. Does anyone know where to buy it from? Just wondering the best course of action for replacing it. It is obviously an awkward curved shape and there is other wooden parts nailed over the sides of the cab so you couldn't actually replace the whole inside panel without taking it all apart. Any ideas? Of course I could just paint the bits where it peeled black. Link to comment Share on other sites More sharing options...
angs1957 Posted September 30, 2018 Share Posted September 30, 2018 Have a look at Bunnings, they usually have thin sheets that pliable to work with. Link to comment Share on other sites More sharing options...
brentos82 Posted September 30, 2018 Author Share Posted September 30, 2018 Yep but I'm not sure it can be cut perfectly to size before it goes on. And if I stick it on first, id have to cut along the edge with a razor but that won't be successful I don't think... surely theres a better way? Link to comment Share on other sites More sharing options...
Yobs Posted October 2, 2018 Share Posted October 2, 2018 With the original LAI cab i recently restored i ended up removing the vinyl from the inside and just painted it instead. As you've already mentioned, most of these cabs have vinyl fully coating the wood pieces so when they were originally assembled some of that vinyl is under edges (the thickness of the ply/chipboard). The cab i restored had massive chunks missing or damaged so it wasn't viable to replace it i felt. I carefully cut close to all the edges with a hobby knife and then used a heat gun and a paint scraper to help remove all the vinyl, then sanded it to a reasonable finish and painted black. Definitely undercoat the wood first before the top black coat cause chipboard is fairly "thirsty" and soaks up the paint. Link to comment Share on other sites More sharing options...
Super Moderator GIBO Posted October 3, 2018 Super Moderator Share Posted October 3, 2018 Chalk board vinyl is what I use ,also works great for a generic CP overlay, Get it from any sign writer supply store Link to comment Share on other sites More sharing options...
