RaoulJuke Posted September 13, 2018 Share Posted September 13, 2018 At a recent hosueball i was introduced to the magical "Novus". Just went to get some off EBay however came across it comes in types 1,2 & 3. Is there a particular one that is the unanimous choice ? Link to comment Share on other sites More sharing options...
ajfclark Posted September 13, 2018 Share Posted September 13, 2018 At a recent hosueball i was introduced to the magical "Novus". Just went to get some off EBay however came across it comes in types 1,2 & 3. Is there a particular one that is the unanimous choice ?They are related but different products with different uses, like different grits in sand paper: 3 for deep scratches, quite abrasive 2 for small scratches, a little abrasive 1 to finish and shine, not abrasive In my experience 3 is not frequently used in pinball. I only use 2 when I do a full strip and clean of a filthy machine. I use 1 when I'm polishing plastics. Link to comment Share on other sites More sharing options...
RaoulJuke Posted September 13, 2018 Author Share Posted September 13, 2018 They are related but different products with different uses, like different grits in sand paper: 3 for deep scratches, quite abrasive 2 for small scratches, a little abrasive 1 to finish and shine, not abrasive In my experience 3 is not frequently used in pinball. I only use 2 when I do a full strip and clean of a filthy machine. I use 1 when I'm polishing plastics. Cheers mate - these guys were using it on a play field, I'm assuming that it was most likely #2 for that? Mainly what i am using it for Link to comment Share on other sites More sharing options...
Administrators furballx Posted September 13, 2018 Administrators Share Posted September 13, 2018 #2 is generally accepted as best for most general pinball applications (Playfield + plastics). Dave Link to comment Share on other sites More sharing options...
ajfclark Posted September 13, 2018 Share Posted September 13, 2018 Cheers mate - these guys were using it on a play field, I'm assuming that it was most likely #2 for that? Mainly what i am using it forYes, #2 is great for cleaning a playfield if you need to use something abrasive. Once it's been cleaned though I don't find that I need to use Novus very often at all. I usually start with a vacuum. Microfibre cloth. Then naphtha (shellite). Anything that doesn't get off I might try Novus #2 . Deep ball swirl won't come out without removing part or all of the top coat so I usually leave it. Wax with pure carnauba paste wax. I'm only working on older machines. Diamond coated playfields (Terminator 2?) and beyond might be different. They'll certainly hold up to the use of Novus #2 better, but I still would not use it as my every time cleaner. Link to comment Share on other sites More sharing options...
onetaste Posted September 14, 2018 Share Posted September 14, 2018 Agreed, novus 2 to clean up something really bad, don’t use it every time. For maintenance I use Mr Sheen to clean and polish everything including rubbers and Novus 1 to clean the flipper rubbers (they don’t behave the same w mr sheen eg post pass is ruined). Link to comment Share on other sites More sharing options...
Administrators Arcade King Posted September 14, 2018 Administrators Share Posted September 14, 2018 https://www.aussiearcade.com/search.php?searchid=11152760 Link to comment Share on other sites More sharing options...
ajfclark Posted September 15, 2018 Share Posted September 15, 2018 https://www.aussiearcade.com/search.php?searchid=11152760 Sorry - no matches. Please try some different terms. Link to comment Share on other sites More sharing options...
Administrators Arcade King Posted September 15, 2018 Administrators Share Posted September 15, 2018 hmm i guess the search expires. Go click advanced search in top right , in keyword(s) type novus then select "Search titles only" then click search now. That will bring up a stack of novus threads. Link to comment Share on other sites More sharing options...
