Likes Likes:  0
Results 1 to 8 of 8
Thread: WOZ Fault
    Nov 2016
    Queensland
    245
    4 Post(s)
    60 Post(s)
    WOZ Fault
    Any WOZ owners had this fault ?
    Cannot find required map name .
    Wont boot up
    Aug 2014
    NSW
    609
    41 Post(s)
    152 Post(s)
    So the fault is that it doesn’t boot?
    Thought you had a lights problem...
    Nov 2016
    Queensland
    245
    4 Post(s)
    60 Post(s)
    Both says cannot find required map name .
    when trying to find obvious fault causing this ( no luck there ) discovered cables tucked up in loom and that Capture Dorothy led board missing
    Aug 2014
    NSW
    609
    41 Post(s)
    152 Post(s)
    Quote Originally Posted by gardog62 View Post
    Hmmm.... WOZ can be frustrating when a board goes, but it will be even worse if you are completely missing one. These can be bypassed, and connect the cables to the next board in line, go into settings and disable the one you are missing. However you would be better of ordering a new one and not bypassing it.
    Then hopefully all will be back to normal. (Only If no other boards are gone also)
    Jun 2006
    Pinball Central
    2,373
    44 Post(s)
    352 Post(s)
    Wont boot up
    remove a refit sata cables to the SSD drive
    Australian Distributors for Jersey Jack Pinball, Planetary Pinball, Chicago Gaming, American Pinball.
    Your one Stop Shop For New Pinball & Arcade Games.
  6. #6
    Nov 2016
    Queensland
    245
    4 Post(s)
    60 Post(s)
    You are talking to a techtard .I am guessing some sort of hard drive and assoc cables .
    I am assuming this must be dont when off turned off ?
  7. #7
    Jun 2006
    Pinball Central
    2,373
    44 Post(s)
    352 Post(s)
    yes turn off
  8. #8
    Nov 2016
    Queensland
    245
    4 Post(s)
    60 Post(s)
    Thanks Wayne reseating sata cable to ssd did the trick machine now fires up .
    # 1 Completely missing the capture Dorothy lamp board # 15-0006-00 plug a tail just floating will have to check wiring loops also .
    # 2 Upper part of playfield lit not lower half # 8 down on yellow brick road .another issue to sort .
  1. AC/DC fault please help.
    By GORGAR 1 in forum Pinball Technical and Repair Questions
    Last Post: 14th November 2016, 10:27 PM
  2. aa just went down again looks like its my fault
    By @lien_Zed in forum General Chat
    Last Post: 4th April 2012, 02:18 PM
  3. AFM divertor fault
    By ricindahunting in forum Pinball Technical and Repair Questions
    Last Post: 19th July 2011, 09:02 PM
  4. SF2 CE graphics fault
    By huds in forum Arcade Technical and Repair Questions
    Last Post: 23rd August 2010, 11:20 AM
  5. SEGA NAOMI 2 FAULT (weird fault)
    By staceyamusements in forum Arcade Technical and Repair Questions
    Last Post: 15th March 2010, 09:33 PM
