Results 1 to 5 of 5
Thread: X Files Sega transistor issue
    Nov 2014
    NSW
    409
    12 Post(s)
    102 Post(s)
    Have found my Q1 transistor associated with the trough up kicker coil keeps blowing out. Swapped a good tested driver board that lasted for a few days only. Tested coil for ohms ok also swapped out coil diode with no luck so far.
    From what I've been reading these older deleted transistors, the 20N10L, wasn't the best and the recommended irl540n is better but will that be enough? What other things should i consider? Could the opro switch associated with this coil have anything to do with it? It appeared to check out ok also. Any suggested would be great thanks.
    Sent from my SM-G925I using Aussie Arcade mobile app
    Jul 2011
    Junee , Near Wagga NSW
    474
    1 Post(s)
    80 Post(s)
    Try changing the coil , it may have an intermittent short that is blowing the transistor.
    Mar 2010
    Wimmera, Victoria
    6,520
    106 Post(s)
    1791 Post(s)
    Is the plunger sticking causing the tranny to overheat?
    My pins: Wild life EM, Top Score Em, Space Mission EM, Target Alpha EM, Cleopatra SS, Pin*Bot SS, Indiana Jones WPC, Black~Rose WPC.
    My Arcades: Funland Rifle EM, Hankin Table 20", Mame 20" Horizontal Cab, 17 in 1 Horizontal 20" cab, Outrun2 sit down game rear projection, Foosball table.
    Nov 2014
    NSW
    409
    12 Post(s)
    102 Post(s)
    Quote Originally Posted by Gemini2544 View Post
    No it seems to be moving freely. Tested coil for ohms and so on but changing it might be worth a try id say.
    Sent from my SM-G925I using Tapatalk
    Jul 2009
    SA
    2,637
    82 Post(s)
    751 Post(s)
    you could try a 1n5404 diode on the coil instead of the standard 1n4004
  1. X Files Sega.
    By Jamie in forum Pinball Technical and Repair Questions
    Last Post: 3 Weeks Ago, 06:01 PM
  2. X Files Sega
    Last Post: 28th September 2018, 08:17 AM
  3. X-Files Pinball - Sega
    By Nookie in forum Pinball
    Last Post: 1st May 2017, 07:56 PM
