skindog Posted January 9, 2019 Share Posted January 9, 2019 Hi all. Rebuilding a flipper on my TZ and can’t get the sleeve out of the coil. Any hints would be appreciated thanks. Link to comment Share on other sites More sharing options...
0 illawarra_steelers Posted January 9, 2019 Share Posted January 9, 2019 usually means your coil is cooked Link to comment Share on other sites More sharing options...
0 skindog Posted January 9, 2019 Author Share Posted January 9, 2019 Yeah thought so. Thanks Tony. Prob best to just replace the coil eh? Why would it cook? Something else wrong further down the line maybe? Link to comment Share on other sites More sharing options...
0 wiredoug Posted January 9, 2019 Share Posted January 9, 2019 they can be stuck 'just enough' to not come out and still work fine. if you're not being obsessive and the coil work another option is to just leave the sleeve in it. Link to comment Share on other sites More sharing options...
0 robm Posted January 9, 2019 Share Posted January 9, 2019 You can knock the old one out with a new one sometimes or find exactly the right sized socket. Other alternative is to slip a leg of needle nose pliers or flathead screwdriver down one side and mangle the old one out. Sent from my ALP-L29 using Tapatalk Link to comment Share on other sites More sharing options...
0 skindog Posted January 9, 2019 Author Share Posted January 9, 2019 Thanks guys. I’ll keep working on it and see if I can save it. Link to comment Share on other sites More sharing options...
0 ocyen Posted January 9, 2019 Share Posted January 9, 2019 You can knock the old one out with a new one sometimes or find exactly the right sized socket. Other alternative is to slip a leg of needle nose pliers or flathead screwdriver down one side and mangle the old one out. Sent from my ALP-L29 using Tapatalk That's the trick I use, too - using another sleeve to push the old one out. Link to comment Share on other sites More sharing options...
0 Autosteve Posted January 9, 2019 Share Posted January 9, 2019 A round file, the more course, the better. Should take about 2 minutes to file away one side of the sleeve and then you can pull out what's left. Try installing a new sleeve afterwards but if it jams going in, get the file onto it till it does go in as intended. Not unusual to have perfectly working coils that have been swollen at one stage but they certainly don't need replacing when a quick filing will keep them running Link to comment Share on other sites More sharing options...
0 Dedrok Posted January 9, 2019 Share Posted January 9, 2019 Nut driver the correct size and tap it out, but the new one will struggle going in. All else fails, do the file trick. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
0 ajfclark Posted January 9, 2019 Share Posted January 9, 2019 As the sleeve is stuck, the coil may have got too hot at some point in its life. Before trying to save it, I'd check the resistances of the coil against a known good or reference (https://www.flippers.com/coil-resistance.html) to make sure the internal insulation of the coil hasn't been damaged. If it's too far out of spec I'd replace it rather than trying to sneak the sleeve out. Link to comment Share on other sites More sharing options...
0 Gemini2544 Posted January 9, 2019 Share Posted January 9, 2019 Can you see any discoloration or burn mark inside the sleeve, this would be where it's stuck. Link to comment Share on other sites More sharing options...
0 skindog Posted January 9, 2019 Author Share Posted January 9, 2019 Thanks everyone got it out. Worked needle nose pliers in and broke it apart. New sleeve went in fine and the flipper has been rebuilt. Think I was being a bit of a Nancy coz I didn’t want to damage the coil but it’s working fine. I appreciate all comments from you blokes. Link to comment Share on other sites More sharing options...
skindog
Hi all.
11 answers to this question
