Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Cutting MDF with a jigsaw
    Aug 2018
    SA
    116
    2 Post(s)
    43 Post(s)
    Hi all,
    Was wondering if its possible to cut both side panels with the jigsaw by clamping two pieces of 18mm MDF together or will the cut end up being too crap? I realize the jigsaw blade has some flex in it so even single panel cuts results in a slightly wobbly feel when running my finger along regardless of cutting directly along the line. I was thinking two panels will probably make this wobble even more noticeable.
    Or should I just mark one piece from the other?
    Derek.
    May 2009
    NSW
    6,235
    161 Post(s)
    1436 Post(s)
    throw out your jigsaw and get one of these. i bloody love mine!
    Sep 2008
    Melbourne
    663
    69 Post(s)
    229 Post(s)
    What it that? I think I need one!
    Sent from my SM-G955F using Aussie Arcade mobile app
    Jul 2009
    SA
    3,002
    94 Post(s)
    858 Post(s)
    Quote Originally Posted by megaderek View Post
    Hi all,
    Derek.
    Jigsaws don't like cutting thick pieces and you will end up with a badly tapered edge.
    I would suggest cutting as many straight edges as possible with a circular saw, then rough cutting the remaining edges on one panel at a time and then finishing it off with a router
    You can use the first panel as a template for the router for the second panel.
    Apr 2012
    我不想乱跑,但我确实想戒&#25
    3,069
    96 Post(s)
    997 Post(s)
    Hi all,
    Derek.
    I find it best to cut one Piece and get it perfect, then Use a router to cut the second piece, using the first one as a template. Much better result
    using this type of bit
    Edit, Boots beat me to it lol
    Aug 2009
    Shepparton Vic
    5,844
    291 Post(s)
    1844 Post(s)
    Quote Originally Posted by nmercury View Post
    It's a mini chainsaw.
    Pretty neat device.
    Aug 2018
    SA
    116
    2 Post(s)
    43 Post(s)
    that mini-chainsaw looks good, might give that a go next time (running a tight budget on this one)
    I have a flush cut router bit although the blade length is 20mm so would that be okay for 18mm MDF as it'd only be 1mm either side at best? or can it be done in two overlapping goes?
    May 2009
    NSW
    6,235
    161 Post(s)
    1436 Post(s)
    it's a nanoblade chainsaw. A brilliant device for DIY'ers that cuts neater, at variable speeds, and you can plunge cut with ease, no need to pre-drill like you need to with a jigsaw.
    it really is the ducks guts, get one, you wont regret it
    Jun 2008
    Brisbane, QLD
    2,677
    261 Post(s)
    517 Post(s)
    Quote Originally Posted by jason1 View Post
    Yep, this is how I do it.
    When using 8mm MDF I'll make a template first out of 16mm MDF (less effort sanding) then use that to make the first side panel, use it to trace the rough outline of the second panel, rough cut with a jigsaw/circular saw with about 5mm overlap then flush trim the second panel around the first panel.
    I can quickly knock up another cab next time using the template.
    The mini chainsaw is a brilliant idea, will have to look into getting one.
    Jul 2009
    SA
    3,002
    94 Post(s)
    858 Post(s)
    Just to add, make sure you have good breathing protection
    And no washing on the line if doing it outside
  1. Stupid pinball jigsaw... Lol
    By ROLLERBALL in forum Pinball
    Last Post: 25th March 2015, 04:40 PM
  2. Cutting plexi
    By Lord-Data in forum Arcade
    Last Post: 30th March 2014, 01:10 PM
  3. cutting mdf
    By 370parsons in forum M.A.M.E Emulation Projects and Discussion
    Last Post: 26th January 2009, 05:59 PM
