Thanks Thanks:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Cutting MDF with a jigsaw
    Aug 2018
    SA
    17
    0 Post(s)
    7 Post(s)
    Hi all,
    Was wondering if its possible to cut both side panels with the jigsaw by clamping two pieces of 18mm MDF together or will the cut end up being too crap? I realize the jigsaw blade has some flex in it so even single panel cuts results in a slightly wobbly feel when running my finger along regardless of cutting directly along the line. I was thinking two panels will probably make this wobble even more noticeable.
    Or should I just mark one piece from the other?
    Cheers
    Derek.
    May 2009
    NSW - Kianga
    5,898
    143 Post(s)
    1332 Post(s)
    throw out your jigsaw and get one of these. i bloody love mine!
    Sep 2008
    Melbourne
    593
    61 Post(s)
    195 Post(s)
    Quote Originally Posted by Jed View Post
    What it that? I think I need one!
    Sent from my SM-G955F using Aussie Arcade mobile app
    Jul 2009
    SA
    2,641
    82 Post(s)
    752 Post(s)
    Quote Originally Posted by megaderek View Post
    Hi all,
    Cheers
    Derek.
    Jigsaws don't like cutting thick pieces and you will end up with a badly tapered edge.
    I would suggest cutting as many straight edges as possible with a circular saw, then rough cutting the remaining edges on one panel at a time and then finishing it off with a router
    You can use the first panel as a template for the router for the second panel.
    Apr 2012
    qld
    3,069
    89 Post(s)
    903 Post(s)
    Hi all,
    Cheers
    Derek.
    I find it best to cut one Piece and get it perfect, then Use a router to cut the second piece, using the first one as a template. Much better result
    using this type of bit
    Edit, Boots beat me to it lol
  6. #6
    Aug 2009
    Shepparton Vic
    4,739
    236 Post(s)
    1591 Post(s)
    Quote Originally Posted by nmercury View Post
    It's a mini chainsaw.
    Pretty neat device.
  7. #7
    Aug 2018
    SA
    17
    0 Post(s)
    7 Post(s)
    that mini-chainsaw looks good, might give that a go next time (running a tight budget on this one)
    I have a flush cut router bit although the blade length is 20mm so would that be okay for 18mm MDF as it'd only be 1mm either side at best? or can it be done in two overlapping goes?
  8. #8
    May 2009
    NSW - Kianga
    5,898
    143 Post(s)
    1332 Post(s)
    it's a nanoblade chainsaw. A brilliant device for DIY'ers that cuts neater, at variable speeds, and you can plunge cut with ease, no need to pre-drill like you need to with a jigsaw.
    it really is the ducks guts, get one, you wont regret it
  9. #9
    Jun 2008
    Brisbane, QLD
    2,395
    226 Post(s)
    472 Post(s)
    Quote Originally Posted by jason1 View Post
    Yep, this is how I do it.
    When using 8mm MDF I'll make a template first out of 16mm MDF (less effort sanding) then use that to make the first side panel, use it to trace the rough outline of the second panel, rough cut with a jigsaw/circular saw with about 5mm overlap then flush trim the second panel around the first panel.
    I can quickly knock up another cab next time using the template.
    The mini chainsaw is a brilliant idea, will have to look into getting one.
    Namco Starblade - Taito Cocktail 14" x 3, 20" x 2 - NZ SI PtII Upright - Chase HQ DX, Taito Top Speed - Taito Grand Champion - LAI SI Head to Head Cocktail - SI Cocktail Clone x 2, Pong Clone x 3
  10. #10
    Jul 2009
    SA
    2,641
    82 Post(s)
    752 Post(s)
    Just to add, make sure you have good breathing protection
    And no washing on the line if doing it outside
  1. Cutting ply
    By BIG Trev in forum General Chat
    Last Post: 17th March 2016, 03:43 PM
  2. Stupid pinball jigsaw... Lol
    By ROLLERBALL in forum Pinball
    Last Post: 25th March 2015, 06:40 PM
  3. Cutting plexi
    By Lord-Data in forum Arcade
    Last Post: 30th March 2014, 03:10 PM
  4. CUTTING VIDEOS
    By GORGAR 1 in forum General Chat
    Last Post: 3rd May 2010, 01:19 PM
  5. cutting mdf
    By 370parsons in forum Mame Cab Projects and Discussion
    Last Post: 26th January 2009, 07:59 PM
