power supply connections
chaos199
3 answers to this question
AC supply connection wont make a difference internally make sure the earth is common to the ground straps.
If you are changing voltages then you need to make sure the links are in the correct location.
If you are rewiring the plug top that plugs into the socket outlet then yes that makes a difference.
Is it even safe to change the voltages on those? Does that shorten the life span of the power supply? I'm just curious.
The way the transformer is internally wound allows for various voltages, safe and does not shorten the life span of the transformer.
