Results 1 to 8 of 8
Thread: ACDC Cannon problem
    Aug 2010
    SA
    640
    53 Post(s)
    201 Post(s)
    ACDC Cannon problem
    Hi all, I'm messing around with an ACDC pin and it has a cannon issue.
    It moves about one inch to the left then stops and will only move more when I hit the flippers to create vibrations to get it moving again.
    It's not touching or binding on anything top or bottom as I've checked this thoroughly.
    While its trying to move the cannon the small electric motor is still active but nothing else is moving.
    No grub screws or anything is loose with the mech that I can see externally.
    So I'm thinking its the gears inside the gearbox looking mech but not really sure.
    Has anybody else had this issue and can offer some insight please ?
    Nov 2006
    Perth, Australia
    4,724
    116 Post(s)
    477 Post(s)
    Time to replace the motor,Pinball Life have them
    Apr 2014
    Carrum Downs Vic
    608
    75 Post(s)
    176 Post(s)
    Sounds like the gears have gone in the motor. Happened to mine also
    Budgie
    Sep 2013
    South Australia
    914
    90 Post(s)
    393 Post(s)
    Yep, I had to replace my motor
    Aug 2010
    SA
    640
    53 Post(s)
    201 Post(s)
    Thank you for the word on the new ACDC motor gentlemen.
    Bought a new one from RTBB and as usual excellent service from them.
    Ordered it Friday arvo and it arrived Tuesday morning, can't ask for much better than that.
    Installed in game and working perfectly. Happy times
    Apr 2014
    Carrum Downs Vic
    608
    75 Post(s)
    176 Post(s)
    Did you have much trouble installing the cannon ?
    Budgie
    Aug 2010
    SA
    640
    53 Post(s)
    201 Post(s)
    Quote Originally Posted by Budgie View Post
    Take out two small phillips head screws and loosen the 2.5mm allen head grub screw and motor comes out fairly easily.
    Just beware there is a small white plastic washer between the cannon motor and it's mounting plate.
    When I took the old motor off this little part fell out and was lost in the wiring harness for half an hour before I eventually found it.
    Easy to reinstall new motor, just line it all up and whack it in.
    So don't drop that small white plastic washer and it's all gravy.
    Sep 2008
    Melbourne
    600
    64 Post(s)
    199 Post(s)
    Quote Originally Posted by Smithy View Post
    You were lucky!
    My grub screws were caked in locktite. Had to get a mini blow torch onto it to loosen it up!
    Then I stripped the hex grub screw, etc. Nightmare!
    One of the most frustrating jobs I've had to tackle in pinball repair...
    Well done to you.
  1. ACDC Cannon issue
    By Budgie in forum Pinball Technical and Repair Questions
    Last Post: 4th July 2018, 06:56 PM
  2. ACDC cannon Mod - WTF?
    By chopchop in forum Pinball
    Last Post: 18th May 2015, 02:37 PM
  3. ACDC why hit bell with cannon ??
    By Ferro in forum Pinball
    Last Post: 25th March 2014, 07:07 PM
  4. T2 Cannon problem
    By tevo in forum Pinball Technical and Repair Questions
    Last Post: 8th September 2008, 06:46 PM
