- 0
Arcade Monitor AC Power
Recently Browsing 0 members
0xce
Hi,
I have just bought a monitor (which I plan on using for Point Blank). It is a 19" Ducksan with the model number: CGM-1901
From what I can tell it runs directly from AC mains. On the label it shows POWER-TUV: 100-240V~, 50/60Hz, 1.2-0.6A UL: 120VAC, 60Hz, 1.25A. There is a molex type connector with 3 pins: Black, Green/Yellow, and White. The Green/Yellow (I know is ground) is attached to the metal frame. A couple of things I want to clear up before I attempt anything..
How can I confirm which is Live and Neutral ? Is Black guaranteed to be Live?
If I connect a cable which has an Australian plug to the monitor, I would like to confirm that the black would go to "Brown" and the White would go to "Blue" ?
I can provide pics if that will help confirm anything. It does look as though there is some form of transformer on the board. The display cable is wired up to a VGA cable.
Thanks for any advice!
10 answers to this question
