Soldering Iron - Weller or Hakko ???
LAP
12 answers to this question
weller out of those two. you can get parts from radioparts and its more likely to be a real one.. its also likely to last you 20+ years
if you buy a hakko make sure its a real one
Thanks for that.... Do you know how long the cord is on the Weller?
Both stations are fine and have an outstanding reputation. If you are soldering eight hours a day, I suspect that the Weller may come out slightly ahead of the Hakko. Otherwise, if you solder occasionally (say five times a week or so), the Hakko will last you a life time, too, and at a lower price.
I have the Hakko, and it hasn't ever let me down.
Michi.
I’ve been buying stations from these guys for years.
If you want a 100% genuine Hakko then buy with confidence.
The FX-888D including ESD mat is currently on special $174 + GST. (Free Shipping)
https://www.mektronics.com.au/soldering-rework/hakko-stations-irons
Get a good chisel tip whist you are ordering.
Edited by pauly540
link
I think I might get one of these - thanks for the link.
You mention to get a chisel tip; is this what you would recommend for general "pinball soldering" ? Any chance you could link to a tip you would recommend? There's quite a few at the bottom of this page and I'm not sure what the difference between them all is https://www.mektronics.com.au/soldering-rework/hakko-stations-irons/hakko-fx888d-digital-soldering-station-esd-mat.html .
Complete noob here :) Thanks for any suggestions.
The Hakko is a good choice. Good quality at a good price. Plenty of tip options and easy parts availability.
It comes with a fine pointy conical tip. On top of that I'd add a flat conical tip such as the HT18-S6 and a chisel tip such as a HT18-S3.
I’m no repair expert, but for this particular Hakko 888, I’ve have been using:
T18-DL2 for board work, as it has a 2mm tip.
https://www.mektronics.com.au/hakko-solder-tip-to-suit-fx888-20185.html
T18-D32 for heavy gauge stuff, like Gottlieb coil wires. Has a 3.2mm tip.
https://www.mektronics.com.au/hakko-solder-tip-to-suit-fx888-20177.html
The station comes with a standard conical tip, of which I’m not a fan.
You could get a cheap eBay tip kit, until you work out which one you like and then buy a genuine one. It’s all down to what you feel comfortable with.
I also still use a Weller 921ZX for the last 20 years (From Tandy), but they are not available anymore :(
Edited by pauly540
Spelling
Thanks for all the recommendations I ended up going for the Hakko plus got the T18-D32 tip too for good measure all from Mektronics.
Jason
