Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: CRT tv to arcade
    Mar 2012
    VIC
    124
    8 Post(s)
    CRT tv to arcade
    Hi,
    What prerequisites does a crt tv need to have to be suitable for a conversion?
    Is there any models one should steer clear from? Eg. LG flatiron or what not
    Thanks
    Nov 2010
    Brisbane
    5,554
    152 Post(s)
    1322 Post(s)
    If you're buying a universal chassis to hook up to a TV tube, the following are standard rules to stick to.
    1) Avoid Sony Trinitrons, they have a weird neck setup that often makes them incompatible with universal chassis.
    2) Avoid 'pure flat' tubes if you can. They are more difficult to get working with universal chassis. It can be done, but I've been advised by Jomac in the past that they can be a pain in the ass, especially when 26 inches and above.
    3) Go for something from the mid to late 90s that has a curved tube. I have used the following branded tubes with no issues, NEC, Samsung and Panasonic.
    You could always RGB mod a TV chassis, but that's a lot more difficult then buying a universal chassis. Quite a few people on here to RGB mods though, so you can always find out more info. If you do an RGB mod, none of the above rules apply, as you will be using the existing TV chassis and modding it to accept RGB input from whatever arcade setup you plan to hook up to it.
    Mar 2012
    VIC
    124
    8 Post(s)
    Quote Originally Posted by namastepat View Post
    Thanks for that mate
    Sep 2007
    Canberra
    65
    5 Post(s)
    I talked to Joey a couple of months ago and he told me that Jomac doesn't have any SI universal chassis left. They have some 2nd hand Wei-ya chassis and other stuff, but you'll need to make sure your tube suits.
    After that I got a few cheapo chassis from China and they're OK, but not as good as the SI chassis were/are.
    Note that it is getting hard to find anybody that sells generic arcade chassis anymore. "factory closed" was heard often.
    Hoard your good quality CRTs.
    Nov 2010
    Brisbane
    5,554
    152 Post(s)
    1322 Post(s)
    Yep, no Sharp Image from Joey. A sad time indeed.
    The tubepocalypse is approaching.
    I'll be protecting my CRT stash like a dragon protects his gold 🙂
    Sep 2017
    NSW
    272
    2 Post(s)
    73 Post(s)
    I'll be protecting my CRT stash like a dragon protects his gold ��
    The last man standing will have to throw arcade parties
    Mar 2012
    VIC
    124
    8 Post(s)
    Letís say I decide to go the LCD route. Would a 5:4 ratio be a no go because I found a couple that sync from 24khz itís the lowest I could find at 19Ē
    Nov 2010
    Brisbane
    5,554
    152 Post(s)
    1322 Post(s)
    Are you planning on using genuine boards with the machine? The large majority of arcade boards sync at 15khz, only a select few games sync at 24khz like Model 2 stuff and other 90s games. If you're using an LCD, you'd need to be coupling it with a VGA to 15khz converter and results on those vary wildly.
    Mar 2012
    VIC
    124
    8 Post(s)
    I will be running 15khz boards
    Nov 2010
    Brisbane
    5,554
    152 Post(s)
    1322 Post(s)
    Then it's CRT or LCD with a converter. They used to make 19inch LCDs that synced down to 15khz, but they were expensive, like 300-400. Not sure if you can still get them.
  1. Arcade Console 999 In 1 Pandora's Box 5s Retro Arcade Video Games HDMI
    By Autosteve in forum Multi Board Discussion and Help
    Last Post: 20th October 2018, 09:46 AM
  2. Replies: 1
    Last Post: 20th April 2016, 06:29 PM
