KJS Posted June 6, 2018 Share Posted June 6, 2018 Hi all. Just wondering if I might be missing a small spacer or something under the hinge where it meets the plastic ball trail piece? Bit of a lip there and think the balls will possibly damage it over time? Any help appreciated. Link to comment Share on other sites More sharing options...
0 Jesder Posted June 6, 2018 Share Posted June 6, 2018 I believe the two bolts on the upper section of the hinge should pass through the plastic. Here is a photo from a Funhouse i worked on a few months back. The plastic was actually broken as you can see in the photo, with the piece still attached under the hinge. Link to comment Share on other sites More sharing options...
0 KJS Posted June 6, 2018 Author Share Posted June 6, 2018 Interesting thats a new nos nos plastic there and it doesn't extend that far.... Link to comment Share on other sites More sharing options...
0 Jesder Posted June 6, 2018 Share Posted June 6, 2018 Interesting thats a new nos nos plastic there and it doesn't extend that far.... Hang on. Digging further through my photos. I think the plastic you have is fine - looks like the plastic under the hinge is separate. Here is another shot with the other piece installed. My memory was it was broken, but it could simply have been the piece under the hinge was cracked. Regardless, the plastic under the hinge lifted it up higher to the level of the other plastic. Link to comment Share on other sites More sharing options...
0 KJS Posted June 6, 2018 Author Share Posted June 6, 2018 Think you are on it Jesder. Just saw a different plastic online in a repro set. Out comes the scroll saw!!! Link to comment Share on other sites More sharing options...
0 pinball god Posted June 6, 2018 Share Posted June 6, 2018 Um both my original and repro clear plastic had a step at the end. So it actually should be the entire length but the part the trap door hinge sits on is thinner or stepped down from the rest of the plastic piece. It then will sit flush. So the stepped piece plus the hinge thickness equals the thickness of the plastic. Hope this makes sense I suppose you could make a small piece to suit although it would make sense if the plastic was one piece and the end is held down by the trap hinge Link to comment Share on other sites More sharing options...
KJS
5 answers to this question
